BARD
gdavis
Posted: Sat Nov 21, 2015 7:56 pm Post subject:
You need a resistor between the output of the LM324 and the base of the 3904. 1k will probably do.
I would consider replacing the 3904 and LM324 as it's possible you've damaged one or both.
The patch cable may have provided enough resistance for it to function, but when you integrated the two parts together on the same board you reduced the resistance of the connection.
Without getting into too much detail, the base and emitter of a BJT basically form a diode which needs a current limiting resistor (like and LED does). That's why you only see 1V out of the LM324 when it's connected. You've essentially created a short circuit. Google BJTs to learn more about them, lots of info out there. _________________ My synth build blog: http://gndsynth.blogspot.com/ |
BARD
Posted: Sat Nov 21, 2015 8:22 pm Post subject:
Hey Gdavis,
Thanks for your reply!
That was one of the first things I considered when trying to fix this circuit. I just tried it out again with a few different resistors (1, 100, 1k, and 10k) and it did not solve the issue.
Double checked to make sure the LM324 was working by disconnecting it from the rest of the circuit. Took a measurement from the output and it is working still as it should.
Checked the 3904 and it is also working as it should but I switched it out with a fresh one just to be sure.
-Zach |
gdavis
Posted: Sat Nov 21, 2015 8:31 pm Post subject:
BARD wrote: | Hey Gdavis,
That was one of the first things I considered when trying to fix this circuit. I just tried it out again with a few different resistors (1, 100, 1k, and 10k) and it did not solve the issue. |
Did you tap the feedback before or after the resistor? Should be before.
Quote: | Double checked to make sure the LM324 was working by disconnecting it from the rest of the circuit. Took a measurement from the output and it is working still as it should.
Don't trust that it's working when it's not driving anything. It may be able to provide the correct voltage without a load, but as soon as it's loaded it can't supply the current.
Also, if I'm not mistaken it looks like your piezo input is going to create a negative pulse to the opamp when you want a positive one. There might be a little bit of a positive pulse when it recovers which is probably why it triggers but needs amplifying. If you got your polarities right the amplification may not be necessary. _________________ My synth build blog: http://gndsynth.blogspot.com/ |
BARD
Posted: Sat Nov 21, 2015 8:51 pm Post subject:
I probed it with the scope both before and after the resistor.
I switched out the LM324 as well and tried it over again with the added resistor and it yielded the issue I've been having.
And yes! I realized I drew the jacks incorrectly on this schematic. I sent it out like this and didnt know why it wasnt working when I got it back. I noticed my mistake later and fixed it. It was a really ridiculous error haha.
Also, the piezo by itself does not trigger enough for what I'm using it for. I want to be able to increase the gain to make it super sensitive to any vibration. |
gdavis
Posted: Sat Nov 21, 2015 10:07 pm Post subject:
BARD wrote: | I probed it with the scope both before and after the resistor. |
I think you may have misunderstood me. I'm asking where the feedback (gain pot) is connected.
Quote: | I switched out the LM324 as well and tried it over again with the added resistor and it yielded the issue I've been having. |
So even with the 1k resistor connected you still only see 1V directly out of the opamp (before the resistor)? That's baffling, I can't imagine that happening with everything connected correctly.
Quote: | And yes! I realized I drew the jacks incorrectly on this schematic. I sent it out like this and didnt know why it wasnt working when I got it back. I noticed my mistake later and fixed it. It was a really ridiculous error haha. |
Ha, I didn't even notice that, but that's not what I meant. I don't know, you say the original prototype was working so maybe I'm wrong but from my experience with piezos you should get a negative pulse (backwards jack notwithstanding).
Quote: | Also, the piezo by itself does not trigger enough for what I'm using it for. I want to be able to increase the gain to make it super sensitive to any vibration. |
Variable sensitivity is certainly nice to have, nothing wrong with that, just not sure that you aren't getting reduced sensitivity due to the negative pulse I mentioned above.
I'm not sure I'm following everything you've done, maybe I can try and breadboard it up myself and see what's going on. Do you have a link to the piezo element you're using? _________________ My synth build blog: http://gndsynth.blogspot.com/ |
BARD
Posted: Sun Nov 22, 2015 1:55 pm Post subject:
Quote: | I'm asking where the feedback (gain pot) is connected. |
Sorry I misunderstood you. The gain pot is shown in the schematic. Leg 1 feeds back into the non inverting input and leg 2 receives the out put on the LM324.
Quote: | from my experience with piezos you should get a negative pulse |
I did notice this when I first started working with this circuit. It still worked well. The M324 amplifies the positive pulse that follows the negative pulse. And since the LM324 is a single supply, it doesn't amplify the negative.
HOWEVER, I probably could have just used an inverting amplifier. Don't see any reason it wouldn't work and maybe it will give me better results.
The only issue is if I ever want to use this circuit with other types of microphones and instruments, will an inverting amplifier be an issue?
Quote: | Variable sensitivity is certainly nice to have, nothing wrong with that, just not sure that you aren't getting reduced sensitivity due to the negative pulse I mentioned above. |
And yah I see what you're saying. It must be amplifying the 2nd transient from the piezo - the positive upswing. Not sure the exact term for it. But it has worked perfectly as two separate modules. I've been able to decrease and increase the sensitivity with my gain pot so that it triggers off of the lightest drum hits or barely triggers unless I hit a spot on the rim close to where the piezo is mounted.
That is what's blowing my mind right now. It has worked. I've used it. I've seen it work exactly the way I wanted. But there's some issue with having it in the same circuit.
If you think it could be the resistance between the two separate modules then maybe I was connecting something incorrectly when I tried it out. Although I'm pretty sure I did it right.
I'm also wondering if there's some sort of buffering issue. I tried a unity gain follower between the circuits on the breadboard but that did nothing.
Again I appreciate your responses. They've been helpful regardless of the unsolved mystery. |
gdavis
Posted: Sun Nov 22, 2015 5:20 pm Post subject:
BARD wrote: | Quote: | I'm asking where the feedback (gain pot) is connected. |
Sorry I misunderstood you. The gain pot is shown in the schematic. Leg 1 feeds back into the non inverting input and leg 2 receives the out put on the LM324. |
Ya, but the resistor isn't shown. I wanted to make sure that the pot is connected directly to the opamp output and not after the resistor.
Quote: | Quote: | from my experience with piezos you should get a negative pulse |
HOWEVER, I probably could have just used an inverting amplifier. Don't see any reason it wouldn't work and maybe it will give me better results. |
An inverting amp would probably fix the polarity, but I don't think it's necessary. You can just reverse the resistor and piezo so that the piezo is connected to 5V, the other end is connected to the resistor and the resistor is connected to ground. This should give a positive going pulse.
Quote: | The only issue is if I ever want to use this circuit with other types of microphones and instruments, will an inverting amplifier be an issue? |
By itself, no. If you're combining the signal with another (i.e. if you used two mic's on something and ran them to two different preamps) you could have phase issues.
Quote: | Quote: | Variable sensitivity is certainly nice to have, nothing wrong with that, just not sure that you aren't getting reduced sensitivity due to the negative pulse I mentioned above. |
And yah I see what you're saying. It must be amplifying the 2nd transient from the piezo - the positive upswing. Not sure the exact term for it. |
Good, sounds like we're on the same page
Quote: | But it has worked perfectly as two separate modules. I've been able to decrease and increase the sensitivity with my gain pot so that it triggers off of the lightest drum hits or barely triggers unless I hit a spot on the rim close to where the piezo is mounted. |
Ya, I don't think the polarity thing is the cause of it not working, just something I noticed.
Quote: | That is what's blowing my mind right now. It has worked. I've used it. I've seen it work exactly the way I wanted. But there's some issue with having it in the same circuit.
If you think it could be the resistance between the two separate modules then maybe I was connecting something incorrectly when I tried it out. Although I'm pretty sure I did it right. |
Ya, this kind of thing is frustrating. Real circuits have parasitic capacitance, resistance and inductance. This is going to change between the patched circuits and the combined circuit. So assuming you didn't make any mistakes this is what I'm focusing on.
There may be more than one thing going on.
You absolutely need a resistor between the opamp and transistor to prevent damage. Any functionality you get out of the circuit without that is just going to be luck. So that's one issue, but if it still doesn't work, we need to look at other things.
Another possibility might be that the pulse is too quick. The capacitance of the patch cord might have lengthened the pulse allowing the circuit to work, but when you combined the circuits you lowered that capacitance and narrowed the pulse to the point that it doesn't trigger the inverter.
Quote: | I'm also wondering if there's some sort of buffering issue. I tried a unity gain follower between the circuits on the breadboard but that did nothing. |
I don't think it's a buffer issue, the opamp shouldn't have any trouble driving the transistor (assuming the opamp and transistor haven't been damaged by being connected without the resistor).
Quote: | Again I appreciate your responses. They've been helpful regardless of the unsolved mystery. |
No problem, sorry I haven't been able to solve it. Need to keep going through step by step. You still haven't told me exactly what's happening when you put the resistor in between the opamp and transistor. Does the opamp output look OK? Do you see a pulse on the collector of the transistor? Do you still see it at the inverter input? _________________ My synth build blog: http://gndsynth.blogspot.com/ |
BARD
Posted: Mon Nov 23, 2015 7:05 pm Post subject:
I threw a 1k resistor from the lm324 output into the 3904 again. Then I took a measurement before the resistor which I thought I had already done....but apparently I didnt because I'm now getting a little under 4 volts out of the 324!
I havent been able to fully test out whether or not this will fix the mystery of why the proto works and the PCB doesn't. I need to test it out with a real drum I think.
When I take the measurements after the resister going into the 3904, it is still only putting around 1v into the transistor. From what you've said this is normal and I believe you! But whats the science behind this? Is there really no way to overdrive the base of the 3904?
Thanks for your help, for real! I'm feeling good about this. |
