<on air> Twyndyllyngs - Live in person Chez Mosc
  Various Artists Live streaming concert in memory of Antimon
recreating G2 features in the G1
Page 1 of 1 [11 Posts]
Vader77
PostPosted: Wed Feb 10, 2016 9:06 am    Post subject: recreating G2 features in the G1 Reply with quote  Mark this post and the followings unread
Is there any way of recreating on the G1 some of the extra features found in the random modules of the G2? I'm interested the step probability and edge functions in the pattern and clock generators and was wondering if some of the logic modules can do the same thing in put if the right combination. Confused
Are there any other tricks that give some of the G2 newer modules functionality?
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Wed Feb 10, 2016 9:34 pm    Post subject: Re: recreating G2 features in the G1 Reply with quote  Mark this post and the followings unread
you can do the step probability with a Sample+Hold and cross fader.
the input to the s+h is your usual noise source via a cross fader, the second cross fader input is the output of the s+h. The more feedback, the smaller the step size.
Would a glide module do for the edge?
Vader77
PostPosted: Thu Feb 11, 2016 2:35 pm    Post subject: Re: recreating G2 features in the G1 Reply with quote  Mark this post and the followings unread
Thanks Ian, id there any way you can clock this to external MIDI? Confused
Also the seed function is useful for saving the same rhythmic position on the S&H is there any trick using the reset function on a regular LFO and combining with a S&H?
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Thu Feb 11, 2016 11:30 pm    Post subject: Re: recreating G2 features in the G1 Reply with quote  Mark this post and the followings unread
I have never used the G1 but the manual lists a midi master module and clock dividers. Divide by 6 should give you 16th note timing?
Vader77
PostPosted: Fri Feb 12, 2016 4:37 am    Post subject: Re: recreating G2 features in the G1 Reply with quote  Mark this post and the followings unread
yeah but the S&H clock input is being fed back by the other fader output if I've got this right? Neutral
Think I need a screen shot
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Fri Feb 12, 2016 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, the clock just activates the hold on the rising edge.
The output is mixed back into the sample input.
 Filesize:  40.38 KB
 Viewed:  4096 Time(s)
Vader77
PostPosted: Sat Feb 13, 2016 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
alas there is no dedicated S&H module on the G1 like the one in your diagram Sad
thanks anyway man Smile
Audio files: 213
G2 patch files: 319
PostPosted: Sat Feb 13, 2016 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Vader77 wrote:
alas there is no dedicated S&H module on the G1 like the one in your diagram :(
It is on the audio tab, 6th from left.
Vader77
PostPosted: Sat Feb 13, 2016 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
OMG as if I haven't seen this module before! Embarassed
I'm well on the way now cheers. Very Happy
Now trying to get similar results or emulating the step probability in the G2 pattern generators by replacing the noise source with the G1 pattern module.
getting there....... Confused
Audio files: 213
G2 patch files: 319
PostPosted: Sat Feb 13, 2016 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Of course Cool
wikter
PostPosted: Fri Jun 10, 2016 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
What about controlling parameters using external MIDI CC ring led encoders?
I've used my BCR2000 and it's superb for edition.
The only things to do is assignind midi CC and then send all CC status from the G1 panel.
