 Forum index » DIY Hardware and Software » The Repair Shop
Muteable instruments module tester problems
Page 1 of 1 [3 Posts]
bamboombaps
PostPosted: Tue May 03, 2016 4:56 am    Post subject: Muteable instruments module tester problems Reply with quote  Mark this post and the followings unread
Ive inherited a previously DIY'd module tester and it has issues
When i power it up it lights up but the lcd is unreadable, on full block similar to this (not mine) http://mutable-instruments.net/forum/uploads/thumbnails/FileUpload/e7/b248f7ea3fa35f97ed5766cf283d85.jpg.
adjusting the contrast trimmer does not help, but it does adjust the brightness.
I compared the behaviour of the menus on a working unit and the behaviour on the broken unit seems to mirror that of the menus on the working one. ie if there are 4 options to cycle on the working one, there are 4 'states' to cycle through on the dodgy one, before there's no change.
The leds do not light up at all. i tested spare leds against the leads of those installed to see if they had been installed incorrectly, but no dice
when i plug a lead into the audio out socket there is an output tone. due to the faulty lcd screen i dont know how to find the menu to attempt to adjust it.
the previous owner suggested he may have fried the chip but no info beyond that other that he had never got it working
ive tried the muteable forum but nothing so far, i may try creating a new topic rather than just posting on a long dead build thread...
PostPosted: Tue May 03, 2016 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Pull all the ICs and check the basics. Power, component orientation, continuity, values. If the microprocessor is dodgy -- have you tried a known-good one?
bamboombaps
PostPosted: Sat Jun 04, 2016 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
this is resolved. it was a shady screen and a dodgy psu!
all working now
