Stereo to Mono
Page 1 of 1 [11 Posts]
PostPosted: Fri Jul 07, 2017 5:17 pm    Post subject: Stereo to Mono Reply with quote  Mark this post and the followings unread
1. When mixing a stereo signal into mono should the amplification be 0.5 since the two signals have the potential to be twice as loud once mixed?
2. What power supply voltages should I use for a line level signal? I am thinking of using a TL072.
JacobWatters.com
Audio files: 219
G2 patch files: 319
PostPosted: Fri Jul 07, 2017 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
1 - yes and no and no .. to avoid clipping at all cost (for fully correlated signals - or split mono) use 0.5 ... however when the signals are uncorrelated (noise) you'd want to use 0.707 to keep the perceived volume level the same .. however when the signals are anti-correlated (like a left / right ping pong) you'd want 1 even. For music its somewhere in between usually ...
0.707 is the square root of 0.5 .. as to why .. it's all about throwing dice and counting .. erm statistics.
Ideally add a volume control Shocked
Ideally add a cross fader too Shocked
2 - a couple of volts of headroom, or maybe 3, should give decent performance .. as line levels are around a volt and a pibolar bower subbly is ideal .. +5 and -5V .. that would leave some headroom too.
PostPosted: Fri Jul 07, 2017 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan! That should be easy to do. I will aim for 0.7 and use a trimpot to set it manually.
JacobWatters.com
Audio files: 584
PostPosted: Sat Jul 08, 2017 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
.. a pibolar bower subbly ..
I've got to get me one of those! Shocked Laughing
SoundCloud BandCamp Stickney Synthyards Captain Collider
Audio files: 219
G2 patch files: 319
PostPosted: Sat Jul 08, 2017 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Is easy to do PHOBos, just before order exchange p&b keys Laughing
what i forgot about the 5V ... that is a practical minimum of course .. the maximum is in the datasheet .. and then just pick what suits you.
PostPosted: Sun Jul 09, 2017 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info. Is this suitable? Do I need to add small caps in the feedback of the opamps to filter out high frequency noise, or is that not required? If so, what would be a good value to use?
Stereo to mono schematic
 Filesize:  47.1 KB
 Viewed:  91 Time(s)
JacobWatters.com
Audio files: 219
G2 patch files: 319
PostPosted: Sun Jul 09, 2017 5:11 am    Post subject: Reply with quote  Mark this post and the followings unread
TL should be stable without the lil caps.
... But I would not do the volume control pot in the feedback ... at the very least connect the wiper to one of the sides .. as otherwise when the wiper has bad contact things will get LOUD.
... But also .. you will need wires from the opamp to the pot and you may introduce unwanted signals this way being picked up by the wires .. or introduce inductance when the wires are longish. Better to do do the 'traditional thing' .. with a pot after the first opamp .. when you do not want to allow the signal to go to zero add a resistor between the pot and the ground.
Audio files: 584
PostPosted: Sun Jul 09, 2017 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd leave the (trim)pot out altogether and just use a 33K resistor, that'll give you a gain of about 0.7.
Depending on what it is for you might be able to get away with a passive solution using just resistors.
PostPosted: Wed Aug 16, 2017 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan and Phobos for the help. I went with the fixed 33k. It works perfectly. It was for the TV input on this cabinet:
https://www.instagram.com/p/BX3KMSFFikd/
JacobWatters.com
Audio files: 584
PostPosted: Wed Aug 16, 2017 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
good to hear it worked Smile
did you have to replace anything in the cabinet like capacitors, tubes, speakers, as it is rather old ?
PostPosted: Wed Aug 16, 2017 9:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Luckily, the radio/reveiver section worked fine.
I had to change some of the speakers. It has on old electrostatic tweeter that still works.
I had to do some work on the turntable, which was kind of a new and interesting project because it is all mechinal and I am used to electronics.
I also updated the ungrounded plug to a grounded version.
Electrostatic tweeter
 Filesize:  94.29 KB
 Viewed:  87 Time(s)
New grounded plug.
 Filesize:  48.43 KB
 Viewed:  85 Time(s)
Stereo to mono
 Filesize:  98.67 KB
 Viewed:  82 Time(s)
RCA jack hang out the back - sloppy but simple.
 Filesize:  36.91 KB
 Viewed:  81 Time(s)
JacobWatters.com
