Keeping my lunetta in tune with autotune pedal
Page 1 of 1 [6 Posts]
mike page
PostPosted: Tue Mar 20, 2018 4:53 am    Post subject: Keeping my lunetta in tune with autotune pedal Reply with quote  Mark this post and the followings unread
Hello all, just thought I'd share my sneaky tip for making my lunetta more melodic. This may be heresy to some, but im not too dogmatic and will incorporate anything I feel like into my system.
Ive been using a Helicon C1 auto tune pedal and it works well!
Snapping the funky lunetta squall in neat semitones.
I think however it could be improved by suitable input buffering.
The pedal is expecting a mic input so low impedance I guess (the manual saying input impedance is 2.68k ohms, and output is 200ohms). Any tips on suitable buffering techniques?
Audio files: 147
PostPosted: Tue Mar 20, 2018 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Since it's a Lunetta, you can just try different size resistors until you get a decent sound.
Sounds like an interesting experiment. How about posting some sound examples?
mike page
PostPosted: Wed Mar 21, 2018 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
here you go, live one take with my lunetta.
sequenced main voice ---> autotune pedal ---> resonant filter ---> EHX super ego
https://soundcloud.com/michaelanimationpage/coda
Audio files: 618
PostPosted: Fri Mar 23, 2018 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds good! Very Happy
I don't think impedance is much of a problem but levels could be. Output levels from a lunetta are pretty high
while a mic input usualy expects a pretty low level. A potentiometer followed by an opamp for buffering should
give some decent results. You could also take a look at the output section of the NANDulator which uses a
transistor.
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
mike page
PostPosted: Wed May 30, 2018 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Ive been having a problem with using this pedal.
Using an impedance transformer I borrowed from a friend seemed to sort it out,
but actually I think the problem isnt impedance but the fact the the pedal always has phantom power on! I think ive been sending 48v to my lunetta!
LFLab
PostPosted: Wed May 30, 2018 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well,if you are using batterij power,there probably is a cap on the output. Just needs to be a cap with quate rated voltage.
