4051 in reverse
Page 1 of 1 [6 Posts]
CHRISKELLY
PostPosted: Tue May 01, 2018 6:12 am    Post subject: 4051 in reverse Reply with quote  Mark this post and the followings unread
Picked up some 4051 chips to use, and thought that i could send 1 of 10 inputs in to get a binary out. The plan was to use a 4017 to cycle through 1 to 10, so that the binary outs could switch on/off three tones to create a little melody.
Didnt seem to work so i'm guessing that it works by binary input with 1 to 10 outputs Crying or Very sad
Is this true or can it be used either way?
If not, is there another chip that will do this for me?
Chris
Steveg
PostPosted: Tue May 01, 2018 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Chris,
The 4051 is a bi-directional analog switcher. So it should work like you want although it is 8:1 not 10:1. Not sure how you would drive the addresses from a 4017. I suspect that isn't working like you might have thought. You need 3 digital inputs for the a, b & c address selectors. You can use three oscillators or three outputs of a counter or a shift register.
Steve
Audio files: 607
PostPosted: Tue May 01, 2018 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
If I understand correctly what you are trying to achive you might be looking for a priority encoder like the CD4532.
However using a 4017 + 4532 to get a binary count seems a bit silly as you can just use an binary counter instead.
But with the 2 chips you can easily mix up the order so maybe that's what you want.
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
CHRISKELLY
PostPosted: Tue May 01, 2018 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys
Sorry Steve i meant 8 inputs not 10!
What i was hoping for was to cycle 3 notes in binary:
A, B and C
First step - C (0 0 1)
2nd - B (0 1 0)
3rd - B + C (0 1 1)
4th - A (1 0 0)
5th - A + C (1 0 1)
etc
If that makes sense?
Audio files: 607
PostPosted: Tue May 01, 2018 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
how are the notes produced ? as you could use any binary counter for that sequence (CD4040, CD4060, CD4029, CD4520 and there are more).
CHRISKELLY
PostPosted: Tue May 01, 2018 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh yes of course a 4040 would work! Thanks for the suggestions Very Happy
I've got an APC to create a tone, then made the 3rd and 5th of that same tone produced using 4046 PLL's. They feed into the inputs of a 4066 and i was thinking of ways fo switch them on and off in a more interesting way.
