SayersWeb
Joined: Apr 07, 2003 Posts: 62 Location: Sugar Land, Texas
Posted: Fri Aug 17, 2018 3:17 pm Post subject:
Noisy Outputs? |
The G2 Engine arrived... looks great, but immediatly upon connecting it was apparent that it is quite noisy. I connected outputs 1 & 2 and there is a background hiss noise that is loud enough to be a problem. Is this a common issue with the G2?
I switched the cables to outputs 3 & 4 and they are fine, the noise is not there. This may be workable, but every single patch needs changing to use the new outputs.
Any info, ideas, suggestions would be greatly appreciated. _________________ Sayer - Home Page |
Joined: Apr 03, 2004 Posts: 24083 Location: The Netherlands, Enschede
Audio files: 278
Posted: Fri Aug 17, 2018 4:59 pm Post subject:
Is the noise still there with USB disconnected?
Edit: or MIDI ... _________________ Jan
SayersWeb
Posted: Fri Aug 17, 2018 10:05 pm Post subject:
Blue Hell wrote: | Is the noise still there with USB disconnected?
Edit: or MIDI ... |
That is a great question, I will try it out.
The USB cable and audio cables were previously connected to a Waldorf Streichfett (same midi and audio interface, just replaced the Streichfett with the G2 using same cables) and there was no problem. The Streichfett has moved to a new place in the studio. _________________ Sayer - Home Page |
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Sun Aug 19, 2018 5:55 am Post subject:
Re: Noisy Outputs? |
SayersWeb wrote: | The G2 Engine arrived... looks great, but immediatly upon connecting it was apparent that it is quite noisy. I connected outputs 1 & 2 and there is a background hiss noise that is loud enough to be a problem. Is this a common issue with the G2?
Any info, ideas, suggestions would be greatly appreciated. |
Noise on Outputs 1 & 2, but not 3 &4… that is odd…
How about the Headphones output? It is a stereo mix of Outputs 1 & 2. If the noise is not there, then you could use that instead of the 1 & 2 output jacks. Caution: the Headphones output level is much louder than the Output jack levels, and the G2 Engine has no Master Level control, so be sure to reduce the patch levels before listening with headphones. _________________ varice |
SayersWeb
Posted: Tue Aug 21, 2018 5:57 am Post subject:
Outputs switched back to 1 & 2 and the noise is not there anymore. Have no idea why, but it sounds fine now. So happy about that.
Next up is to figure out why some patches sync to DAW master clock while others won't, they go quiet. I am having fun with the G2! _________________ Sayer - Home Page |
