 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Polysynth with some tricks i learned in July
Page 1 of 1 [9 Posts]
Wan
G2 patch files: 46
PostPosted: Thu Jul 28, 2005 12:31 pm    Post subject: Polysynth with some tricks i learned in July Reply with quote  Mark this post and the followings unread
Hi all,
Learned some things on the forum/list last month. A lot actually, too much to contain in one patch. But a few tricks i did put in this patch, the jitter trick from Tim, a filter based on a design by Rob (see his workshops) and last but not least his spectrum tilter. It is assigned to Knob E-3-8, don't forget to toggle it on and off, it's doing quite some magic in taming the high frequencies.
Many thanks to Tim and Rob for this insights. I owe you guys, see this patch as a feeble attempt trying to give something back.
Edit: Made a change in the credits, see discussion below
JulySynth V1.pch2
A polysynth with some tricks i learned in July 2005 (jitter and tilt that is).
 Filename:  JulySynth V1.pch2
 Filesize:  6.22 KB
 Downloaded:  1377 Time(s)
Grtz Wan
Audio files: 143
PostPosted: Thu Jul 28, 2005 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wouldn't say feeble. I like this, especially variation 7.
Maybe we should a an item to the wish list - a tilt filter module. Maybe one built into an output module. Not a must have obviously, but it would be convenient.
Wan
G2 patch files: 46
PostPosted: Thu Jul 28, 2005 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your positive comments mosc. I am not surprised you like var 7 the most, it's the most "electronic" sounding, and i do think you are most in electronic sounding sounds, electro-music anyone Very Happy
I did think similar thoughts as you, clavia would just be smart to make a dedicated spectrum tilt module, it seems nearly all of us users like it.
I've incorporated it already in several of my patches i plan to use live.
Grtz Wan
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Jul 28, 2005 3:10 pm    Post subject: Re: Polysynth with some tricks i learned in July Reply with quote  Mark this post and the followings unread
Wan wrote:
Hi all,
Learned some things on the forum/list last month. A lot actually, too much to contain in one patch. But a few tricks i did put in this patch, the jitter trick from g2ian,
<snip>
Wasn't the jitter idea by me? (Or did I miss a previous post by g2ian?)
Wan
G2 patch files: 46
PostPosted: Thu Jul 28, 2005 3:46 pm    Post subject: Re: Polysynth with some tricks i learned in July Reply with quote  Mark this post and the followings unread
Oops, you're completely right Tim. You made that jitter thing in this thread http://electro-music.com/forum/topic-7223.html
Somehow i've got the two of you mixed up on this topic Embarassed . Now you are both exceptional good patchers, so i hope you don't mind it, being mixed up with g2ian. Sorry for it, i will adjust the patch as soon as my music pc is active again.
Grtz Wan
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Thu Jul 28, 2005 3:59 pm    Post subject: Re: Polysynth with some tricks i learned in July Reply with quote  Mark this post and the followings unread
tim wrote:
Wan wrote:
Hi all,
<snip>
Ha ha, I thought that configuration was from one of Rob’s posts. My post on the subject used S+H’s and a noise source, which uses a little less dsp but only if you already have a noise source in your patch.
My post was in the DORn performance back in January, Robs version was posted in Feb, See Rob's post here.
http://electro-music.com/forum/topic-5101.html
I think Wans variation is a little different though. Oh and nice patch Wan BTW.
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Jul 28, 2005 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey hey, no prob, I wasn't fishing for compliments Wink
Just wanted to know if I posted something which was redundant, i.e. already mentioned before.
Great patch, btw.
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Jul 28, 2005 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
As I see now from g2ians post, I DID post something redundant.
Never mind, folks.
Originality is an illusion anyway.
(Nothing is created, it just changes form.)
Rob
G2 patch files: 109
PostPosted: Sat Jul 30, 2005 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Never mind, folks.
Just as long as it doesn't keep you from posting more patches, Tim.
