Busboard with 28 headers (MOTM + Curetronic/Eurorack)
Page 1 of 1 [23 Posts]
sonicwarrior
PostPosted: Mon Feb 03, 2014 11:55 am    Post subject:  Busboard with 28 headers (MOTM + Curetronic/Eurorack)
Subject description: Boards in stock
As the MOTM-960 is not to my liking because the spacing between the slots is too crowded I made my own busboard design with 4 rows instead of the 3 of the MOTM-960. So it has footprints for 28 headers instead 21. 4 of them can be fitted alternatively with Curetronic/Eurorack connectors and 2 of them have the additional 4 pins to allow the fitting of 14 pin Club of the Knobs connectors. Because of the width I could only fit in two of the COTK connectors there.
As I got a question regarding diodes and capacitors: I think protection should be done in the module itself and the PSU. Coupling, too, that's why there are neither diodes nor capacitors on this busboard.
As images are better than 1000 words here is a picture of the populated prototype:
The size is 20 cm x 9 cm and the PCB is double sided with through plating.
If there is enough interest (let's say 20) I will order a batch of 50 PCBs which would then cost 18 € each plus postage and packing.
Edit: Ordered the batch.
Edit 16th February, 2017: 0 boards left.
sonicwarrior
PostPosted: Sat Feb 08, 2014 4:07 am    Post subject: Re: Busboard with 28 headers (MOTM + Curetronic/Eurorack)
Subject description: Interest check
Currently there is interest for 10 boards, so 10 to go for starting a batch.
Open for comments and improvement suggestions. I mainly didn't add a terminal block footprint because I only like the one on the MOTM-960 and don't know where to get it (and with it a datasheet with a layout description).
sonicwarrior
PostPosted: Sun Feb 16, 2014 3:41 pm    Post subject: Re: Busboard with 28 headers (MOTM + Curetronic/Eurorack)
To give this a bump here is pic mounted inside a cabinet and an MOTM cable:
It shows that there is enough space for the cables to not have to bend them.
PostPosted: Mon Feb 17, 2014 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's beautiful, I'm interested, but my money is tied up in TTSH stuff right now...hopefully you will continue to offer them....
Paradigm X
PostPosted: Tue Feb 18, 2014 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, its prefect, but i just bought two oakley dizzies, so ok for the moment.
Perfect feature set.
sonicwarrior
PostPosted: Wed Feb 19, 2014 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I already installed a page as it seems likely that I get enough interest for batch (currently there have to be additional interest in 7 PCBs to make it happen):
http://www.sdiy.de/en/projects/busboard.html
sonicwarrior
PostPosted: Fri Feb 28, 2014 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I just ordered the boards. They should be here around the 12th of March.
sonicwarrior
PostPosted: Thu Mar 13, 2014 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The boards arrived:
Please let me know if you want one. I guess that stock will last some time.
sonicwarrior
PostPosted: Mon Sep 01, 2014 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
31 boards are left.
sonicwarrior
PostPosted: Fri Sep 05, 2014 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: 29 boards are left now.
sonicwarrior
PostPosted: Sat Jan 17, 2015 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
27 boards left.
PostPosted: Sat Jan 17, 2015 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
What do you estimate shipping would be to Chicago, IL, USA? For 3 if it's important.
sonicwarrior
PostPosted: Sat Jan 17, 2015 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
5.85 € with tracking (needed for Paypal buyer security) or 3.70 € without (e.g. personal payment via Paypal).
sonicwarrior
PostPosted: Sat Feb 07, 2015 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
24 left now. Smile
sonicwarrior
PostPosted: Sun Apr 19, 2015 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
18 left now.
Edit: Is anyone interested in complete kits with MOTM connectors and those metal connectors for the PSU connection?
sonicwarrior
PostPosted: Thu May 21, 2015 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
16 left now.
sonicwarrior
PostPosted: Tue Dec 08, 2015 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
15 left.
sonicwarrior
PostPosted: Wed Jun 08, 2016 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update: 12 left.
sonicwarrior
PostPosted: Sun Jan 08, 2017 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update: 9 left.
Price discount until end of January: 16 Euro per board. Cool
sonicwarrior
PostPosted: Wed Jan 11, 2017 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
7 left.
sonicwarrior
PostPosted: Thu Jan 12, 2017 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
5 left.
Thinking about using 2-3 of them myself and instead selling my Synthtech MOTM-960 boards. Confused
sonicwarrior
PostPosted: Mon Feb 06, 2017 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
4 left
sonicwarrior
PostPosted: Wed Feb 15, 2017 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
All gone now
Edit: If someone tells me what I need to export Gerber files in the right way from Sprint Layout I can put those online.
