 Forum index » Instruments and Equipment » Nord stage
Nord Stage 88 Volume Problems
Page 1 of 1 [3 Posts]
theshowbizkid
PostPosted: Sun Aug 30, 2009 5:37 am    Post subject: Nord Stage 88 Volume Problems
Subject description: Volume issues when using splits
When using splits (for example piano and organ), I've noticed the piano can make the organ 'dip' in volume when played simultaneously. I'm using the stereo (1&2) main outputs.
Has anyone else noticed issues with this?
I suppose I need to assign the organs and pianos to different outputs?
oktoplus
PostPosted: Sun Aug 30, 2009 11:46 am    Post subject: Re: Nord Stage 88 Volume Problems
theshowbizkid wrote:
When using splits (for example piano and organ), piano can make the organ 'dip' in volume when played simultaneously.
Maybe you just have the onboard compressor in use.
theshowbizkid
PostPosted: Mon Aug 31, 2009 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, compressor isn't active.
