Using Nord Lead 2X and Mac OS X
Page 1 of 2 [42 Posts]
Keyboard Cowboy
G2 patch files: 4
PostPosted: Sun Nov 16, 2008 10:44 am    Post subject: Using Nord Lead 2X and Mac OS X Reply with quote  Mark this post and the followings unread
Having recently acquired and made working (with the help of Wout and Blue Hell) a Lead 2X, I've been wondering how to get new sounds into the keyboard from Mac OS X. Now, I've used a G2 with my mac before and that was pretty easy - just use the editor and USB to transfer patches, but I understand that the Leads use midi and sysex data.
Searching through previous posts I've seen that in order to get patches from computer to keyboard, on a mac, the best thing to use is SysEx Librarian. I've installed this and been able to load .mid files as well as .syx files into it's main window. However, when pressing "play" (which is supposed to transfer the files via midi), none of the patches are loaded into my keyboard. The activity in Sysex Librarian says that it is transferring the files, but no sounds get into the keyboard.
I've tested the midi in and out of the keyboard with my midi interface (a MOTU Microlite) and it's working fine. I've been able to change programs and banks in Logic Studio and seen settings change on the Lead 2X, so I'm sure that the midi in (to the keyboard) is working.
Can anyone guide me how to get this working?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Nov 16, 2008 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't use Mac, so all I can say, knowing there is no Memory Protect, are you sure you are sending to the right location in your synth? BTW I should make a midi file copy of your memory location first!!!
Only the 4 RAM locations can receive complete banks.
Programs can't receive Performance and visa versa.
Program should receive a single SysEx file in the buffer memory, all the time, also in ROM.
Wout
Keyboard Cowboy
G2 patch files: 4
PostPosted: Sun Nov 16, 2008 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Wout
You always seem to come to the rescue! Smile
I have set up the Lead 2X to Slot A, and program 1 (bank 0). I'm set in Program mode. I have tried sending single syx files to program 1, but the sound in my keyboard does not change. Should the keyboard indicate that it has received the patch? There is absolutely no indication that any 'received' activity has taken place. No flashing LED's, no message in the patch bank window display...
I have done a Bulk Dump of Bank 0 - 3 (the RAM locations). This worked without problem. I also sent the same banks back to the Lead 2X to see if it would receive bank dumps. This DOES work. It appears that only individual sysex files will not be received by the keyboard.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Nov 16, 2008 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
A soon you load a single SysEx file (BTW 139 bytes) most of the LEDs on the Panel has to change, unless you are loading the same file which is already active on the synth Very Happy
So I think there's something wrong with the SysEx itself.
Could you post one file here, the one you are trying to upload?
And maybe some files of the synth itself?
Don't know if I'm able to look at it this night, but who knows Smile
Please be patient... Rolling Eyes
Wout
Keyboard Cowboy
G2 patch files: 4
PostPosted: Sun Nov 16, 2008 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am being patient - I have plenty of time and not in a rush. Smile
It's just that I've read the manual and several posts here and no one seems to have the same problem... I think I attract weird problems Rolling Eyes
Anyway, onto the problem, then! It's sysex and midi files that are located in the electro-music directory that I'm trying to upload to the keyboard:
http://nm-archives.electro-music.com/020_NordLead2/021_Patches/0100_Library01_Bank01/
I've tried individual .syx files (ie. the first one and a few others) and the main .mid file.
Thanks for trying to help, Wout. Wink
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Nov 16, 2008 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I know that archive, mainly because I made it myself Smile
As you can guess, it works perfectly here...
So, could it be the downloading is scrambled in any way?
Can you monitor the file in any way?
Wout
BobTheDog
PostPosted: Sun Nov 16, 2008 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
It may be worth setting the "pause between played messages" which you can get at from the preferences in Sysex Librarian. Try 50 milliseconds.
You can also try lowering the transmit speed.
May work Question
Cheer
Andy
Keyboard Cowboy
G2 patch files: 4
PostPosted: Sun Nov 16, 2008 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure how it would be scrambled - there are about 28kb of data per midi file and each sysex file is about 4kb... how could I monitor them?
Yep, tried this - also not working...
I will try setting up my PC laptop (I'll find it under some cobwebs somewhere!) to get this working. Maybe my Nord doesn't like mac's...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Nov 16, 2008 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oops, each SysEx file should be only 139 bytes and by no way 'about 4,000 bytes'!
The Midi file is 24,782 bytes exact! To monitor (showing the file in normal letters) is there some tool like Midi-OX or Midi Send to the Mac? Surely there is somewhere
Could also be the other way around Wink
Wout
Keyboard Cowboy
G2 patch files: 4
PostPosted: Mon Nov 17, 2008 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout, you are right - these are the file sizes I'm getting. When looking at these file in mac windows, it only registers 4kb as the smallest, but in Sysex Librarian it gives the correct size in bytes.
I've also tried using a program called MIDI monitor when outputting from Sysex Library to the Nord and it registers that there are 109 files sent from mac to Nord, yet the Nord still does not register that it has received these files.
Is there some way the Nord needs to be set 'to receive' or put in a 'receiving state'. It's just really strange that it will accept a .mid file that had been previously dumped from it to the mac, but won't accept any new .mid or .syx files...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Nov 17, 2008 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
... Is there some way the Nord needs to be set 'to receive' or put in a 'receiving state'. It's just really strange that it will accept a .mid file that had been previously dumped from it to the mac, but won't accept any new .mid or .syx files...
Not that I know of... Using a single file puts it first in the buffer memory, so nothing has been changed in the memory; a Bank.mid dump wipes out the old bank and replaces it by the uploaded one.
Please send me your downloaded Bank.mid file and a single Program SysEx file, so I can read what's in the file. Maybe something is add to the file somewhere down the line?
Wout
Keyboard Cowboy
G2 patch files: 4
PostPosted: Wed Nov 19, 2008 12:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout, here are the files I've been trying to upload into the synth:
0101PolySynthWheel01.syx
 Filename:  0101PolySynthWheel01.syx
 Filesize:  139 Bytes
 Downloaded:  347 Time(s)
Z01n2lib1b1.mid
 Filename:  Z01n2lib1b1.mid
 Filesize:  24.2 KB
 Downloaded:  367 Time(s)
Keyboard Cowboy
G2 patch files: 4
PostPosted: Wed Nov 19, 2008 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the bank file my 2X produced from a bulk dump and also a single syx file from one patch:
Lead2X_BULK_DUMP_BANK_0.mid
 Filename:  Lead2X_BULK_DUMP_BANK_0.mid
 Filesize:  24.3 KB
 Downloaded:  231 Time(s)
Bank0_Pch_001.syx
 Filename:  Bank0_Pch_001.syx
 Filesize:  139 Bytes
 Downloaded:  194 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Nov 19, 2008 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm gonna check these out Smile
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Nov 19, 2008 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, try this for a chance...
(I had to think about this earlier... Embarassed)
Press [Shift+2xMidiCh] > G.* will appear. This is the Midi Global setting. By using the Up&Down buttons set this to G.16 and press [Shift] again.
I keep my fingers crossed...
Wout
Keyboard Cowboy
G2 patch files: 4
PostPosted: Wed Nov 19, 2008 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout. You rock Exclamation
Very Happy Very Happy Very Happy
That made it work!!!
Your patches are excellent BTW - some really funky sounds that are great for playing... I'm gonna have some fun tonight!
Have a virtual beer or your favourite beverage on me!
Wink
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Nov 19, 2008 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Phooffff...
That was a long time keeping my fingers crossed Wink
I wrote you I had to think earlier about this solution.
Any way, it works Smile
I have to make a special sticky thread about the Midi problems in the NordLead, like 'always reacting to Midi' and 'the Midi Global settings'... Has to wait still some time, maybe in the begining of december...
But in the mean time you can help me: send me some *.mid files of all the banks in the NL2X and also the Performances. I know, its a bit of work, but it is for the community, of course Smile
BTW are yours still intact?
Wout
Keyboard Cowboy
G2 patch files: 4
PostPosted: Wed Nov 19, 2008 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
No problem. These 4 are the mid files from my lead 2X RAM banks. Do you want the ROM banks as well?
Programs -
 Filesize:  24.3 KB
 Downloaded:  217 Time(s)
Lead2X_BULK_DUMP_BANK_1.mid
 Filename:  Lead2X_BULK_DUMP_BANK_1.mid
 Filesize:  24.3 KB
 Downloaded:  235 Time(s)
Lead2X_BULK_DUMP_BANK_2.mid
 Filename:  Lead2X_BULK_DUMP_BANK_2.mid
 Filesize:  24.3 KB
 Downloaded:  228 Time(s)
Lead2X_BULK_DUMP_BANK_3.mid
 Filename:  Lead2X_BULK_DUMP_BANK_3.mid
 Filesize:  24.3 KB
 Downloaded:  199 Time(s)
Keyboard Cowboy
G2 patch files: 4
PostPosted: Wed Nov 19, 2008 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Performance RAM bank:
Lead2X_BULK_DUMP_PERF_BANK_0.mid
 Filename:  Lead2X_BULK_DUMP_PERF_BANK_0.mid
 Filesize:  70.27 KB
 Downloaded:  225 Time(s)
Onyx
PostPosted: Wed Nov 19, 2008 10:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just picked up a 2x tonight, the previous owner said he reset everything however there are a lot of empty slots in the RAM banks.
I tried using the presets for the clavia site but they only fill up 1-40. I have been trying to use your posted bank dumps but for some reason the 2x does not recognize the midi file.
I am able to use the midi file for the clavia site as well as some of the individual sysex files.
But the dump files do not work. Sad
Any help would be appreciated.
thanks,
-paul
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Nov 19, 2008 10:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
... Do you want the ROM banks as well?
Yes, please! Smile
Onyx wrote:
... But the dump files do not work. Sad ...
welcome Onyx
You tried the Global Midi settings already? (See some posts above)
I'll try, but at the moment I have to go to a two days conference without any computer connection, so I've heard. It means I can only try in two days Sad Please send me a remembering post this evening or tomorrow, because I could consider this thread to be 'done with'...! Smile
Wout
Onyx
PostPosted: Wed Nov 19, 2008 10:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Wout,
Yes all the prior posts (set it to G.12)
What I don't quite understand is.
The presets file from the clavia site, works, well at least it appears to, it counts up to 40 and then stops, I am assuming for now that that file is for the Lead 2 and that it only contains 40 presets in bank 0. Assuming that is correct then I tested slot 41 and was able to load and save a single patch in sysex format.
SO that seems good but when I try and use the 4 banks, using midi-ox the 2x does not respond at all. So I am trying to figure out what the differences are.
thanks,
-paul
Onyx
PostPosted: Wed Nov 19, 2008 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK just did somoe more trouble shooting, even though the clavia presets does trigger activity in the 2x, it does not actually overwrite the back, so that seems to be working half way. For example I changed patch 38 and save, then i run the clavia bank from midi-ox, i see it count up to 39 (something is going o.n in there) but when i go back to pathc 38 it has not ben overwritten.
Hmmmm......
Now that I think about it, I am trying to figure out how the guy that sold it to me managed to create the empty slots in the banks in the first place?
I mean there are a bunch of pathes that produce no sound at all. i just assumed he erased them, but after reading the manual there does not appear to be any way to do that.
I am confusing myslelf Shocked
Onyx
PostPosted: Wed Nov 19, 2008 11:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok some progress...
This midi file went through fine.
http://nm-archives.electro-music.com/020_NordLead2/021_Patches/0100_Library01_Bank01/Z01n2lib1b1.mid
Well at least something i working. Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Nov 21, 2008 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nah! Press [Shift+2xMidiCh] > G.* will appear. This is the Midi Global setting. By using the Up&Down buttons set this to G.16 and press [Shift] again.
... Now that I think about it, I am trying to figure out how the guy that sold it to me managed to create the empty slots in the banks in the first place?
Maybe he just set all the parameters to 'zero' and saved by hand; or he uploaded such a 'zero' Program Bank created by Copy&Paste.
Wout
