Pitch Bender
Page 1 of 1 [14 Posts]
PostPosted: Sun Jan 23, 2011 9:57 am    Post subject: Pitch Bender
Subject description: What do you use?
What do you use for bender the pitch on your DIY synths? The local electronics shop said they didn't have anything that would work.
I was thinking about maybe trying to get an EQ pot to use. They have a notch in the middle so I know when it's back in the center.
I tested it out, and a 1K pot is way too much resistance. I need something with very little resistance. Or I might be able to use another pot that controls how much the bender effects the current.
Is there a better options that has linear resistance across the entire range, but somehow returns to center easily?
XCenter
PostPosted: Sun Jan 23, 2011 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
What about Doepfer?
http://www.doepfer.de/zubeh_d.htm#Modulationsr%C3%A4der
How may I be of disservice?
Music for conscious listening @ http://www.fmdelight.de/
PostPosted: Sun Jan 23, 2011 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
That would be ideal, but I'm looking for an inexpensive option. I'll check the local synth shop this week and see if they have any of those kicking around for a decent price.
richardc64
Audio files: 26
PostPosted: Sun Jan 23, 2011 1:31 pm    Post subject: Re: Pitch Bender
Huh? If anything, 1K might be too little resistance, if you've connected the ends of the pot to +V and -V. The range obtained can be tailored by varying the resistor at the pot wiper. You do have a resistor there, yes?
Exactly what are you attempting to bend?
PostPosted: Sun Jan 23, 2011 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am working on a top octave synth that uses 2 sets of 2 40106's to create the top octave, which is then divided by a bunch of 4040's.
I tested a 1K pot on the power supply going to the 40106's. Adjusting it changes the speed that the capacitors on the oscillators charge up, which changes the frequency of the oscillation. But the 1K pot varied it too much.
Dan Lavin
Audio files: 21
PostPosted: Tue Jan 25, 2011 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Just to clarify, are you using the 1K pot as a voltage divider? In other words is one end hooked to +V and one end to Gnd with the wiper hooked to the voltage supply of the 40106's?
If that's the case, you could add another resistor between the bottom (where ground is currently connected) and run the other side of the resistor to ground. This would limit the voltage swing to the 40106.
Synth DIY since 1977!
PostPosted: Wed Jan 26, 2011 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dan. That's what I was thinking of doing, but use a variable resistor so I can control how much the first one changes the pitch. That way I could bend the pitch a few semitones or an entire octave.
But what I need is a pot that I can return to the center so I know when the oscillator is back to the note that I have it tuned to produce. I checked 2 music stores, an electronics shop and a surplus shop that has a lot of electronics. None of them have anything I can use. I might have to order something on the net, which usually means I have to pay shipping and brokerage and it ends up costing a lot more than it's worth (unless I can find someplace in Canada that has it).
Inventor
Audio files: 267
PostPosted: Wed Jan 26, 2011 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
can you make a pot is on-center indicator? just a window comparator that lights an LED when the pot is centered comes to mind...
Les
Dan Lavin
Audio files: 21
PostPosted: Wed Jan 26, 2011 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
You could use this mini-joystick from Spark Fun. It's pretty cheap and you could maybe use the other axis for control modulation?
Put in in series with a regular adjustable pot to set the range of the pitch bend.
http://www.sparkfun.com/products/9032
inlifeindeath
PostPosted: Wed Jan 26, 2011 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
thats what i was going to suggest Smile you could also salvage an old video game remote. The thumbsticks are identical to that part.
PostPosted: Thu Jan 27, 2011 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's perfect! I picked up a used controller today and tested it out. It actually has too little resistance, but maybe another resister inline will help - or I can try swapping the trimpot in the joystick with one of a higher value.
PostPosted: Fri Jan 28, 2011 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
or try to find a defective MIDI controller keyboard. i buddy gave me one for free and i salvaged the pitchwheels and the fatar diode matrix keyboard from it...
richardc64
Audio files: 26
PostPosted: Fri Jan 28, 2011 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I extracted the circuit below from something that starved a 40106 and a quad XOR, so it should work with 2x 40106. The transistor can be any g.p. NPN. You'll have to tailor the resistors to the pot you want to use.
But there may still be a problem: getting all 12 oscillators to change by the correct amount to maintain that 12th root of 2 per semitone relationship. That's why this http://electro-music.com/forum/topic-45583.html is a much better idea. Yeah, it's 10 more ICs than two 40106s, but you wouldn't have to mess around with different R and C values and only one oscillator has to be varied for Range and Pitch Bend.
From the "FrankenGenerator", which Search for some reason cannot find.
 Filesize:  3.7 KB
 Viewed:  4147 Time(s)
PostPosted: Fri Jan 28, 2011 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Richard. I saw that thread for the other top octave synth, but I had difficulty dividing the notes. I don't really understand how it works and when I tried to replicate the schematic I didn't get the same result. I don't know how the 4040 is able to divide by semitones. Maybe I'll try replicating it again to see if I can get it to work for me.
