Median calculator for 7 values
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Oct 15, 2014 12:38 pm    Post subject: Median calculator for 7 values Reply with quote  Mark this post and the followings unread
In response to this thread:
http://www.electro-music.com/forum/post-404332.html
This building block calculates the median from 7 inputted values.
It's a highly G2-specific solution, based on a neat trick that uses a cascade of feedbacked min/max modules as treacle-down-scheme of "hold if higher, pass on if lower" functions in conjunction with multiplexing. The output refreshes every 0.291 ms.
Special thanks to Moody33 for the inspiration and testing.
t
7ValuesMedian_TK.pch2
Calculates the median from 7 inputted values.
 Filename:  7ValuesMedian_TK.pch2
 Filesize:  1.73 KB
 Downloaded:  4175 Time(s)
