Two opamp Attack/Release Envelope Generator
Page 1 of 1 [3 Posts]
PostPosted: Fri Feb 24, 2017 12:36 am    Post subject: Two opamp Attack/Release Envelope Generator
Subject description: very simple design but with a drawback....
So I designed a super simple two opamp attack release envelope generator.
But I faced a problem: The release diode next to the 220E resistor will hinder the output from going to 0 volt (hence the 1M resistor parallel with the 22uF capacitor) that's why these two diodes should be Ge or Schottky type with the lowest Vf possible, this goes NOT for the diode on the left hand side over the opamp!.
The switch is substitute for a trigger or gate input, this AR-EG is retriggerable when in Release phase.
The opamps are single supply 0 - 5volt.
Attack time is between 35mS and 8.6Sec with values shown.
This is just a simulation, I will put it on breadboard this weekend, maybe the problem isn't such a big issue after all... Rolling Eyes
Question: Is there an easy way to have the output going fully to gnd potential?
http://tinyurl.com/zh8quso
 Filesize:  118 KB
 Viewed:  426 Time(s)
elektrouwe
PostPosted: Fri Feb 24, 2017 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://tinyurl.com/zevxfsd
PostPosted: Fri Feb 24, 2017 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
The problem now is at the attack side: when you increase the attack potmeter to max, the attack ramp will start after 218 msec. Sad
