Casio SK-5 adapter/sample memory
Page 1 of 1 [3 Posts]
transmisson
PostPosted: Mon Mar 31, 2014 9:56 am    Post subject: Casio SK-5 adapter/sample memory Reply with quote  Mark this post and the followings unread
I've been using the Casio SK-5 live for a couple years now. It actually does a pretty mean lo-fi mellotron impersonation!
The thing that's always bothered me is the need to use batteries to keep the samples in memory. My workaround has been to use rechargeable batteries and keep the samples I need on an iPod in case I have to swap them out and resample on the fly at a gig. Also, as the batteries lose their charge, the samples become even more lo-fi.
I'd like to mod it to keep the samples in memory while using a regular 9v adapter (instead of the stock 7.5v), so a replacement can be easily found while on tour.
I've searched around and seen some mods that folks have done to increase the memory, but four samples is really fine for my needs. Is it possible to just keep the samples from disappearing while using an adapter?
new voodoo
PostPosted: Tue Apr 01, 2014 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's what I have -the old sk-5 service manual.
I havent had a chance to really look into it yet, but I have done a LOT of sk-1 bending and have 2 sk-5's im going to get to after doing few hr-15s and I may be able to give you more info in about a week.
in the meantime perhaps this will help:
CASIO_SK-5_SRVC MANUAL.pdf
casio sk-5 service manual
 Filename:  CASIO_SK-5_SRVC MANUAL.pdf
 Filesize:  14.87 MB
 Downloaded:  586 Time(s)
www.newvoodoodesign.com
-my creations, bends & bendable pieces
-vintage parts & tubes, IC's & audio chips
-oddities & weird
newvoodoo.blogspot.com
-bending DIY/projects
-crap
transmisson
PostPosted: Tue Apr 01, 2014 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks so much, that will no doubt be really helpful.
I'd be interested to hear your findings when you get to the bending!
