 Forum index » Instruments and Equipment » OSX as a music workstation
iConnect Midi2
Page 1 of 1 [4 Posts]
cappy2112
PostPosted: Fri Mar 07, 2014 12:47 am    Post subject: iConnect Midi2 Reply with quote  Mark this post and the followings unread
http://momupro.com/iconnectmidi2-review/
Has anyone used this yet? I'm curious if there is much latency
YashN
PostPosted: Mon Mar 24, 2014 11:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Big Doc Savage fan here.
I don't use any physical interface from my iPad to the iMac: I use the latter as a router, so the iPad wirelessly sends and receives MIDI data.
cappy2112
PostPosted: Tue Mar 25, 2014 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Wink
Interesting. I would expect latencies to be worse going over wifi, but that
doesn't appear to be the case.
YashN
PostPosted: Tue Mar 25, 2014 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Latency is very low even with the default settings of the Network panel. Apparently, you can reduce this even more with an ad-hoc network on Mac OS X. I haven't tried and to my ears the current configuration is instantaneous.
