Automations - Record, Edit and Save
Electromagnetic Wave
G2 patch files: 38
PostPosted: Thu May 22, 2014 10:21 pm    Post subject: Automations - Record, Edit and Save
Subject description: knobs movement recording
I hope that this patch is as useful to you as it is for me. We can record, edit and save an automation internally. Smile
This patch is only 1 BAR. But 8 variations = 8 BARS
I'm sure you know how to add more BAR. Or play with the resolution (more/less steps). In my tests I play and record 3 knobs at the same time and everything works fine.
I know the "Polyphonic MIDI Recorder/Looper" patch, from Tim Kleinert. But we can not edit or save the automation because the pach is built with an audio delay line (virtual RAM memory). Thanks to ian-s. He taught me how to use the keyboard to send information other than notes.
**Use this exemple in the Slot A**
Comments and improvements are welcome
EDIT : This patch is not the 1st like this :
http://electro-music.com/forum/post-415094.html#415094
and : http://www.electro-music.com/forum/topic-53997-0
RecAutomation16.pch2
Automations - Record, Edit and Save. Use this exemple is the Slot A
 Filename:  RecAutomation16.pch2
 Filesize:  4.02 KB
 Downloaded:  4347 Time(s)
