 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
USB Yamaha Keyboard to Casio MIDI keyboard
Page 1 of 1 [5 Posts]
brainstormer
PostPosted: Fri Nov 28, 2014 6:47 pm    Post subject: USB Yamaha Keyboard to Casio MIDI keyboard
Subject description: Have interface
I was hoping to go direction from my Yamaha Piaggero USB keyboard to my Casio WT 1350 which is only a MIDI keyboard. I have a USB to MIDI interface cord. I try and get no connection. I would like to just play both keyboards sounds on the Yamaha since it's a 76 key keyboards. Thanks for any help.
Robert Pearson
http://www.paramind.net
http://www.telicalbooks.com
http://www.regenerativemusic.net
PostPosted: Sat Nov 29, 2014 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
USB is only required if you are hooking it up to a computer. You should be able to use a standard MIDI cable to go from one synth to the other.
You may need to adjust something in the synth that is receiving the MIDI data so that it listens to the correct channel. You will need to check the manual for that.
brainstormer
PostPosted: Sat Nov 29, 2014 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Like a lot of modern keyboards, the Yamaha only has usb inputs. One is flat, and the other is the more square kind.
Robert Pearson
PostPosted: Sat Nov 29, 2014 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh. Then you might have to route it through your computer in order to make it work. I have never tried to connect two devices together with usb.
Audio files: 278
PostPosted: Sun Nov 30, 2014 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
You could use one of these if you want to avoid connecting via a computer
http://www.kentonuk.com/products/items/utilities/usb-host.shtml
or maybe this
http://iconnectivity.com/iConnectMIDI1
