Sine wave multiplier circuit - any advice?
Page 1 of 1 [12 Posts]
jurekprzezdziecki
PostPosted: Sat Feb 25, 2017 1:43 am    Post subject: Sine wave multiplier circuit - any advice? Reply with quote  Mark this post and the followings unread
I need a simple multiplier circuit that works with analog sine wave at wide frequency range let's say 10 Hz > 15 kHz. I want the multiple outputs sine wave to be a 0.1, 0.2, 0.3...0.5 x f - so not doubling. Output should be analog.
Could you advice me with that?
Thanks Jurek
JovianPyx
Audio files: 224
PostPosted: Sat Feb 25, 2017 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
sine frequency multiplication (including values less than one) is not easy in analog. It may be possible to do with a PLL and some digital dividers, but it will be a large complex circuit if you need sine wave output. Such a circuit also has built in latency which could be very noticeable. Digital dividers could be used, but again, with possible adverse complexity since the output is rectangular and to get sine from rectangular would require serious filtering. Even at that, there would be differences in amplitude between the different outputs. In my opinion, what you're asking is a really a job for digital signal processing. DSP would produce a result with low latency and will be highly accurate in frequency, amplitude and waveform shape.
HTH
Time flies like a banana.
corruptio optimi pessima
jurekprzezdziecki
PostPosted: Sat Feb 25, 2017 1:23 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Thanks for your advice. Yes it seems like DSP or micro-controller should do the job. Someone also pointed a DDS but all of those are black magic for me.
The thing is a simulation works great so i can't sleep and scratching my head how to make it real:)
JovianPyx
Audio files: 224
PostPosted: Sat Feb 25, 2017 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
What method does the simulation use to do it?
I just thought that multiple sine VCOs might do it if they track very very well, but sine VCO isn't trivial either.
Audio files: 326
PostPosted: Sat Feb 25, 2017 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe a Bode frequency shifter?
What is a DDS BTW?
Audio files: 326
PostPosted: Sat Feb 25, 2017 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or a pitch shifter - depending on what you want to do exactly
jurekprzezdziecki
PostPosted: Sat Feb 25, 2017 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just connected 4 AC voltage sources with different frequencies and amplitudes and summed with a summing amplifier. That's all. One of the inputs is just a "base" frequency. The whole idea comes to mind to use a sort of additive synthesis as a wave folder circuit. So what you have to do is just changing the amplitudes in a range ~100 mVp each. All four frequency multipliers / dividers outputs its frequencies depended from input sine wave. So any input sinewave frequency will get it's 1-4 "xF" which will be summed together as a folded rich in harmonics waveform. Does it make sense to you?
jurekprzezdziecki
PostPosted: Sat Feb 25, 2017 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm... frequency shifters could be a consideration. Depends how the input sine wave would look after a shift = low or high distortion?
PostPosted: Sun Feb 26, 2017 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
What is a DDS BTW?
DDS stands for Direct Digital Synthesis, like with the Analog Devices AD9833 a chip I use a lot in my diy synthesizer.
edit: typo
jurekprzezdziecki
PostPosted: Sun Feb 26, 2017 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
What is a DDS BTW?
DDS stands for Digital Direct Synthesis, like with the Analog Devices AD9833 a chip I use a lot in my diy synthesizer.
Does that chip need to be programmed?
PostPosted: Sun Feb 26, 2017 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I use arduino's for that.
http://www.youtube.com/playlist?list=PLWPX-l4AfDQZniisAteWIYz6geY-YyCaP
Audio files: 326
PostPosted: Sun Feb 26, 2017 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, nice chip :-)
