Using ethernet for short distance patching?
Page 1 of 1 [3 Posts]
Top Top
PostPosted: Wed Aug 29, 2018 2:05 pm    Post subject: Using ethernet for short distance patching?
Subject description: Can each wire in twisted pairs be used as individual conductors for short runs? Crosstalk problems?
I am working on a device from which I would like to be able to break out power and a few streams of pulses from the main "brain."
The circuits sending and receiving the pulses are CMOS logic at 12V.
I need seven simple pulse streams (one at audio rate and six at sub-audio rates), a ground, and a power supply (12v low amperage).
Cat 5e or cat 6 seemed good to me because it is a compact connector, with eight signal lines and a shield, cables are ubiquitous, and the connectors are cheap.
One thing about the ethernet architecture, however, is that it is designed to transfer four streams of data in inverted pairs, and those inverted pairs are physically sent down a twisted pair of wires (eight conductors total).
If I were to run short distances, say 3ft max, do you think there would be significant enough inductive cross-talk between the conductors to cause errors in the streams? Somehow I doubt it would be that significant, but the cable is basically designed, as I understand, to have interference between the twisted strands.
A.M.P. ESOTERIC ELECTRONICS
PostPosted: Wed Aug 29, 2018 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
As long as you have low(ish) impedances on each side, I can’t imagine any problems.
my synth
Top Top
PostPosted: Wed Aug 29, 2018 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
It looks like I would actually have to use cat6a if I wanted to include 8 signals + ground. I didn't realize that a lot of those cat 5/6 connections don't have a grounded shield.
