Dual TB303 VCO going in sync problem.
Page 1 of 1 [5 Posts]
VA1
PostPosted: Fri Dec 14, 2018 7:25 am    Post subject: Dual TB303 VCO going in sync problem. Reply with quote  Mark this post and the followings unread
Hi, i have this problem :
https://www.youtube.com/watch?v=Ome2DR2pmNY&feature=youtu.be
Anyone seen something similar ?, or maybe know how to fix this ?
thanks
ringroad
PostPosted: Sun Dec 16, 2018 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are they sharing the same ground? Your description sounds similar to the symptoms that Broadwave described when making a pair of Arp Odyssey oscillators
VA1
PostPosted: Mon Dec 17, 2018 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, thanks for the reply.
Yes they share the same ground, and its in breadboard,
maybe when soldered it is better ?
i will look into your link, thanks.
VA1
PostPosted: Tue Dec 18, 2018 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Great info.
I was planning on making 2 oscillators in 1 quad opamp circuit,
now i am making each oscillator on individual card with seperate trace to the PSU.
I am also making a waveshaper and sub oscillator on the same card,
with seperate ground just to be sure,
1 card with 2 ground lines.
VA1
PostPosted: Tue Jun 04, 2019 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I like to implement a lock option digitally.
What would be the best way to connect the - ?
Using a 4066 ?, then running at 5 volt or 12 volt ?
