SOP14, SOP16 to DIP adapters - Simple, Cheap and Smallest 1
ixtern
PostPosted: Wed Jun 26, 2019 12:39 am    Post subject: SOP14, SOP16 to DIP adapters - Simple, Cheap and Smallest 1
Subject description: How to make SOP14-16 to DIP adapers to fit into IC sockets - simple
1. Simple adapter.
This adapter is cheap and simple to make - only drawback is asymmetric look and footprint.
First solder pins. To get pins in line you may put them into IC socket before soldering. Remember about correct diameter of pins. Cut out soldered pins from the IC side. Wash pcb with isopropyl alcohol. Then solder IC. Wash pcb again.
Previous part:
http://electro-music.com/forum/topic-71081.html
Next parts:
http://electro-music.com/forum/topic-71083.html
http://electro-music.com/forum/topic-71084.html
PCB for simple adapter.
 Filesize:  495.86 KB
 Viewed:  273 Time(s)
Simple adapter completed - top.
 Filesize:  336.83 KB
 Viewed:  286 Time(s)
Simple adapter completed - bottom.
 Filesize:  259.06 KB
 Viewed:  285 Time(s)
