blinking fader fail & other question
j450nn014n
PostPosted: Thu Dec 26, 2019 4:48 pm    Post subject: blinking fader fail & other question Reply with quote  Mark this post and the followings unread
Hi; I've built a klee and it seems to be working except for 2 problems.
I'm building a synthcube kit
1) the LEDs on the fader are not working. I chose to not use the resistors and opted for the 'bit synced' resistor jumpers rather than the constantly on option. Not sure how to get in there with a probe since when the power's on and everything's connected the resistor jupers are sandwiched inside.
2) when setting the voltages for the Range Switch Positions, they're all showing up as negative. It SEEMS that when I set the 7 ranges to the negative versions of the voltages everything works fine. The 8 setting it set for variable, so it doesn't R41 installed, and I have the 1k resistor for R33, as per my kit, and there is no voltage for that. Any reason why I might be getting a negative voltage? I went through the process twice, thinking I might have flipped a switch somewhere, but nada.
Thanks for any thoughts on this.
