The Moduletta
Page 1 of 3 [63 Posts]
Goto page: 1, 2, 3 Next
synaesthesia
Audio files: 85
PostPosted: Thu Mar 31, 2016 1:42 pm    Post subject: The Moduletta
Subject description: a crossover between Lunettas and modular synths
This is the project I am currently working on. I haven't finished the big new Lunetta Lab yet, but decided to build a smaller one first using the triangle VCO and a few other ideas I had recently. It already works fine on breadboard and I wanted to have manufactured PCBs this time. This was a first for me, and of course there were a few small errors. But overall it came out great and I am very happy with the result.
I call this a Moduletta because it is a cross-over between a Lunetta and simple modular synth circuits. The idea was to have a mixture of analog and digital modules that can be patched together via Dupont cables. All analog modules accept control voltages and almost everything can be connected to everything else. The Moduletta is meant to run from a unipolar power supply of 5V to 9V. The chips could stand more, but my current VCO design doesn't work well above 9V.
There will be four pots for control voltages and four VCOs on the board. Two additional pots are hardwired to control the release and the volume. The digital modules include two simple DACs, an XOR/AND/OR gate, two counters, and two shift registers. The analog modules include a PWM, a VCF, a simple envelope generator, and a mixer with amplifier for a builtin speaker. A line output can be used to connect other devices or headphones.
I will post more info as this project continues. The next step is to design a nice case for the Moduletta.
 Filesize:  1.19 MB
 Viewed:  982 Time(s)
PostPosted: Thu Mar 31, 2016 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
that looks very good! thumleft
synaesthesia
Audio files: 85
PostPosted: Fri Apr 01, 2016 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the VCO circuit that I am using. I have tested that with several batches of 4093s and unfortunately you have to adjust the resistor network even if the chips are from the same manufacturer and only differ in the date code. The benefit is that you can get an amplitude of 2.8 to 3.1V (at 5V) with that trick. The VCO works fine at 5-9 Volts. At higher voltages, different resistor values are needed again. Instead of the 4066, a FET like the BS170 can be used as well.
 Filesize:  75.99 KB
 Viewed:  914 Time(s)
synaesthesia
Audio files: 85
PostPosted: Fri Apr 01, 2016 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
The mixer is a simple resistor network with an LM386 amplifier. The additional 15K resistor makes the response of the linear potentiometer more logarithmic.
This trick is described at http://sound.westhost.com/project01.htm
The line out jack is meant to be used for other devices or headphones, so an additional 4K7 series resistor is added to limit the output volume and save your ears.
 Filesize:  63.62 KB
 Viewed:  847 Time(s)
synaesthesia
Audio files: 85
PostPosted: Fri Apr 01, 2016 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
The VCF is a very simple but effective low pass filter design with a bit of resonance, but no self-resonance. The diode current from a control voltage through a resistor network determines the filter response.
This way it is easy to adapt the desired range of the filter response to the available control voltage. Of course another pot could be used here as well. The control voltage used here is typically in a range of 0-3.5 Volts.
There are two signal inputs, one for analog signals (e.g. from the VCOs) and one for stronger digital signals that are scaled down before being fed into the filter.
Mind that this is a unipolar design. Vref is 1.8V here and taken from a red LED. How convenient, this is exactly half of the usable output range for an LM358 at 5 Volts.
 Filesize:  54.14 KB
 Viewed:  835 Time(s)
synaesthesia
Audio files: 85
PostPosted: Fri Apr 01, 2016 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
And finally, the envelope generator. I omitted the controls for attack, decay and sustain, and only added a potentiometer for the release time. With the values here you can have a range from short drum-like sounds up to a 2 seconds release time. The envelope curve is taken from the voltage at the 10uF capacitor during discharge.
Two inputs for negative or positive trigger signals are available. They are simply connected via small caps plus pull-up/pull-down resistors, and the internal protection diodes of the CMOS gate handle the rest. The BC327 transistor buffers the output from the CMOS gate and handles the quick charge cycle for the cap.
I have experimented a lot with this circuit and the solution that works best for me is to use the voltage at the cap to control the gate of the FET. The signal is sent straight into the drain of the FET. This works because all other inputs in my circuit are referenced to ground.
 Filesize:  53.89 KB
 Viewed:  884 Time(s)
kybernetika
PostPosted: Sat Apr 02, 2016 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow very cool!! Nice idea to put modules together on a pcb
synaesthesia
Audio files: 85
PostPosted: Sat Apr 02, 2016 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
And here is the case for the Moduletta. I visited electrouwe this afternoon and we spent 4 hours on the design for the case (BIG THANKS to Uwe!). We had it right at the second attempt and everything fit together perfectly. The precision of the laser cutter is amazing. The parts were cut from 3mm MDF and they press-fit together and hold even without glue or screws. There will be two addtional parts glued to the sides later and two screws to hold the case together. The speaker sits in the inside with an opening at the back.
The laser cutter at work
 Filesize:  243.63 KB
 Viewed:  777 Time(s)
The final case without finishing
 Filesize:  380.13 KB
 Viewed:  824 Time(s)
synaesthesia
Audio files: 85
PostPosted: Thu Apr 07, 2016 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
And the finished Moduletta in action playing a brief sample patch. The additional side panels are still missing.
The laser put a nice dark brown finish on the edges of the parts. So I decided to give the MDF parts only a finishing using vegetable oil rather than painting them.
1_over_f_noise
PostPosted: Thu Apr 07, 2016 2:19 pm    Post subject: Moduletta PCB Reply with quote  Mark this post and the followings unread
Hi synaesthesia!
What a wonderful work!
I am always really delighted by your projects!
May I ask if (or when) will be available the Moduletta PCB and what will be the price?
I'm trying to use Lunetta systems with my students and this board would certainly be a really functional approach!
Thanks in advance for your reply
Best regards to you and this fantastic group
synaesthesia
Audio files: 85
PostPosted: Thu Apr 07, 2016 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi 1_over_f_noise, sure. I am planning to use the 20 PCBs I have for a DIY Synth workshop near Stuttgart some time around Mai.
I will post the info once the date is confirmed. If there are some PCBs left after the workshop I can make them available.
synaesthesia
Audio files: 85
PostPosted: Sat Apr 09, 2016 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the finished enclosure with the extra side panels and a recording of a patch. Guess what the potentiometer knobs are made from... Wink
The patch uses two shift registers with XOR feedback controlled by a counter. The high frequency is fed through a VCF. The lower frequency is fed through a PWM and envelope generator. Both are controlled by a triangular wave LFO that also drives the counter. The base frequency VCO is controlled by three counter outputs sent through a DAC.
 Filesize:  1.14 MB
 Viewed:  655 Time(s)
Moduletta.mp3
 Filename:  Moduletta.mp3
 Filesize:  2.88 MB
 Downloaded:  1190 Time(s)
1_over_f_noise
PostPosted: Sat Apr 09, 2016 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Good! I suppose that a few of my students could be interested in... I'll will be blocked here due to examinations Sad
Well, I hoped it would be possible of purchasing a few of them more rapidly...anyway, I'll try to wait your news after the workshop Very Happy
1_over_f_noise
PostPosted: Sat Apr 09, 2016 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Could they be some toothpaste caps? Very Happy
rico C
PostPosted: Sat Apr 09, 2016 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm gonna go for caps from tubes of mustard!
Really nice build man, inspiring as always.
synaesthesia
Audio files: 85
PostPosted: Sat Apr 09, 2016 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Mustard it is! Laughing
elektrouwe
PostPosted: Sat Apr 09, 2016 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
another riddle: guess how long we were collecting "mustard knobs" for
the upcoming Moduletta (Mustardetta?) workshop Wink
Mustard Knob Collection
 Filesize:  123.14 KB
 Viewed:  505 Time(s)
cygmu
PostPosted: Sun Apr 10, 2016 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
That is thoroughly marvellous. The sound file you posted reminds me of the opening titles of TV science shows circa 1981. This is meant as a compliment!
Outstanding work.
Audio files: 299
PostPosted: Sun Apr 10, 2016 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
the upcoming Moduletta (Mustardetta?) workshop ;-)
Well ..judging the way they are packed .. they were never used?
Its a great looking device BTW, impressed by that laser cutter work, really nice!
cygmu
PostPosted: Mon Apr 11, 2016 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to be a pain... I can't understand how that circuit works at all. Why doesn't the op-amp integrator just ramp up forever i.e. to saturation and stay there? I can't figure out what causes the triangle wave to ramp down again.
I am sure I'm being stupid here...
PostPosted: Mon Apr 11, 2016 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 4066 discharging to ground, I think.
cygmu
PostPosted: Mon Apr 11, 2016 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply.
That was what I thought, but I still can't see how it works. When the triangle wave output (i.e. voltage at the lower plate of the capacitor) is high, assuming the gate input is high, the NAND will be low so the 4066 is off.
Even if it weren't, is grounding the other plate of the capacitor going to discharge it? I get terribly confused when trying to figure this stuff out.
elektrouwe
PostPosted: Mon Apr 11, 2016 11:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
cygmu wrote:
... is grounding the other plate of the capacitor going to discharge it?
yes, because GND is always more negative than the integrators reference voltage @ pin 3. In fact pin 3 is kept exactly @ CV/2 so ramping up and ramping down voltage are both |CV/2|. the down ramp R 100k is always connected to CV, so if an up ramp happens, current through the switch must be exactly 2x the downramp current to maintain a symmetrical triangle.
That's why R in series in the switch is 47k.
summarized:
I_down_ramp = (CV - CV/2) / R = CV/2R //R=100k
I_up_ramp = (I_down_ramp - (CV/2)/(R/2)
= CV/2R - CV/R = - CV/2R
=> I_up_ramp = - I_down_ramp => sym. triangle
hope this helps
cygmu
PostPosted: Tue Apr 12, 2016 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
elektrouwe wrote:
hope this helps
It really does. Thank you!
As luck would have it, I'm reading Horowitz and Hill The Art of Electronics at the moment, in my quest to understand and build some synthesizers, and this circuit was on the very next page when I opened it up this morning. Their explanation gave me some clues but with the addition of yours I am there.
Many many thanks.
rico C
PostPosted: Tue Apr 12, 2016 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
dang that'a a lot of ham sandwiches! 6 months?
