Nord Modular G2 Engine - patches storing via MIDI
Page 1 of 1 [11 Posts]
Shape84
PostPosted: Fri Oct 02, 2020 3:00 pm    Post subject: Nord Modular G2 Engine - patches storing via MIDI Reply with quote  Mark this post and the followings unread
Hello everyone!
I'm a very new owner of the G2 Engine and looking for help!
Is there any possibility to storing patches (variations) via midi? Is there any cc controller or sysex mesaage responsible for this? I cannot find the information about it. Sad Thanks in advance!
Audio files: 297
PostPosted: Fri Oct 02, 2020 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi & welcome
The manual has a section about it .. http://www.nordkeyboards.com/sites/default/files/files/downloads/manuals/nord-modular-G2/Nord%20Modular%20G2%20English%20User%20Manual%20v1.4%20Edition%201.4x.pdf
page 148 patch and performance requests and dumps.
And then page 17 has a section on how to send dumps from the synth to the computer.
Alsopage 29, 121 .. and some more.
Once you have a patch dump you can just send it back to the synth over MIDI.
Audio files: 297
PostPosted: Fri Oct 02, 2020 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
There also used to be some tooling for this .. but that is a bit complicated IIRC .. https://bluehell.nl/iaf/html/nm-open/nm-open-software.htm .. but I have no idea if this would still work .. and how it worked.
Shape84
PostPosted: Sat Oct 03, 2020 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
It's still unclear to me. Can I store in that way a preset using just a MIDI controller? (without the computer connected to the G2)
Audio files: 297
PostPosted: Sat Oct 03, 2020 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know .. you'd need something able to receive, store and send back MIDI sysex files, but I have no idea what that MIDI controller can do.
When you have a link to it's manual I could have a look at it.
Shape84
PostPosted: Sat Oct 03, 2020 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
The controller model is: Novation 49 SL Mk2.
The manual: https://resource.novationmusic.com/sites/default/files/novation/downloads/4120/english107.pdf
Audio files: 297
PostPosted: Sat Oct 03, 2020 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like it can not do that ...
But maybe I've misunderstood and maybe you just want to select ptaches and variations on the G2?
In that case ... use program change messages and CC70 for changing variations.
Shape84
PostPosted: Sat Oct 03, 2020 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
So, just as I thought. Sad
The idea is:
1. Create patch in the Editor and upload it to the G2.
2. Assign some parameters (osc coarse, filter cutoff etc.) to the 49 Sl.
3. Work standalone (without the computer).
4. Modifying the synth parameters over MIDI and overwrite vatiations from 49 Sl.
Audio files: 297
PostPosted: Sat Oct 03, 2020 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
That sounds doable ... you can assign CC controllers to parameters, and you should be able to do that on the MIDI controller too.
Looks like you'll have to use advanced mode on the MIDI controller.
You'll want to use CC messages to control parameters, it does not matter much which one you use on the MIDI controller, as long as you know which knob, or slider or whatever uses which one.
Then in the G2 editor you can you can right click on just about any knob
, and then select MIDI controller from the popup menu and assign a CC number to that knobe.
When you want to change variations on the G2 you will need to use CC70 - and it looks like this is possible in advanced mode.
Then to slect patches .. you will need bank slect and program change, which can be done from the buttons and the drum pads .. or so it seems.
You'll have to do some menu navigation on the MIDI controller .. the manual is not directly clear to me without having the actual device.
Shape84
PostPosted: Sat Oct 03, 2020 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know I can do it all. But I'm looking for equivalent for button "store as" from a keyboard version - in the form of something that I can assign to the MIDI controller. Anyway many thanks for your time and help. I appreciate!
Audio files: 297
PostPosted: Sat Oct 03, 2020 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah ok .. not seeing how to do that with an engine and a MIDI controller only ... a dedicated computer then ;-)
