Nord Modular G2 Editor 1.62 and OS X High Sierra 10.13.6
Page 1 of 1 [9 Posts]
JennoJackson
PostPosted: Fri Jun 07, 2019 1:54 pm    Post subject: Nord Modular G2 Editor 1.62 and OS X High Sierra 10.13.6 Reply with quote  Mark this post and the followings unread
Hi, my first post here. I have my G2 running with Nord Modular G2 Editor 1.62 on OS X High Sierra 10.13.6. But unfortunately it's not running stable. I get non reproducible errors like "Major Error" and "Usb Connection Lost". Does anyone have the same problems, same system or an idea how to fix it?
Thanks in advance
Jens
Audio files: 296
PostPosted: Fri Jun 07, 2019 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Jens,
not having a solution ... but having the same issues here, my OSX version is a bit later 10.14.2 - Mojave. not really using the G2 lately .. but would be interested to see a fix too.
Jan.
JennoJackson
PostPosted: Sun Jun 09, 2019 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I send a request to North Technical Support. Let's see if they can help.
Rudt
PostPosted: Sun Oct 06, 2019 10:39 am    Post subject: OSX later versions
Subject description: Parallels or VMWare
I'm looking into a solution to run the G2 on later versions of OSX. I've tried Wine to no avail and have also tried parallels and it didn't work either.
of course I had problems installing the USB driver on both for some reason
Rudt
PostPosted: Sun Oct 06, 2019 8:48 pm    Post subject: I found what the problem is Reply with quote  Mark this post and the followings unread
Hi. I'm able to get my G2 working on every mac OS up to Mojave using 1.62 editor. Also able to get it to work on Parallels on a Mac. How? Use an extremely short USB cord. Works fine on Mojave (using an old mac with a regular usb 3 input). Not sure if it works with the newer usb ports on macs.
comma
PostPosted: Wed Nov 13, 2019 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you happen to get any word on this from Nord support?
shhh21
PostPosted: Mon Jan 18, 2021 12:27 pm    Post subject: Re: Nord Modular G2 Editor 1.62 and OS X High Sierra 10.13.6 Reply with quote  Mark this post and the followings unread
Same here. Did you figure out a solution? Currently trying our various options with Parallels in Catalina. Virtualized Windows 10 with Editor 1.62 seems to work perfectly. Virtualized High Sierra seems to constantly be producing MAJOR ERROR issues (loosing connection)…
Second that. Any feedback?
How short?
hugokuva
PostPosted: Mon May 09, 2022 4:19 pm    Post subject: NORD MODULAR G2 EDITOR – OS X HIGH SIERRA 10.13
Subject description: Connection issue between Nord Modular G2 and its Editor on OS X 10.13
Hi there,
I'm facing the same problem.
Anyone have a solution regarding those connection losses under OS X High Sierra? Is the short USB cable working well? If yes, how long should it be?
Also, is there any viable and stable alternative for a G2 editor?
I've tried G2 Editor from FMX but it didn't recognize my synth neither. Anyone experienced this as well?
http://www.bverhue.nl/g2dev/?page_id=17&fbclid=IwAR2nMH87D6dxZo6YTqZsRvmQRMzzL0K6tYj8raaEFZfssboD5AhwrxdwZxw
Thanks for your help Smile
sebber
G2 patch files: 33
PostPosted: Thu Jun 02, 2022 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
You need to install libusb to make that editor work. You may have to install homebrew first (https://brew.sh/index_de) and then download libusb via the shell. Don't ask me how I did it, it was more luck than anything else.
Wine and other apps based on wine won't work with the editor, since there's no way to install the G2's windows USB driver with them. The demo works though.
Fish don't swim. They dive.
