 Forum index » News... » Gear News
RETEXTULE
room
PostPosted: Sat May 20, 2023 3:39 am    Post subject: RETEXTULE
Subject description: Exploratory glitch delay
We are really excited to release :::: RETEXTULE
Exploratory glitch delay module by Fendoap.
https://www.audiobulb.com/RETEXTULE.htm​​​​​​​
RETEXTULE is a 4-parallel looper type effector that can change the playback speed. Interesting textures can be created with parallel loopers with variable playback speed. You can reinforce pad sounds by layering reverse sounds, octaves up, or slightly pitch-shifted sounds. Since the playback speed can be finely set with a decimal point, you can create a mysterious sound that creates a series of non-integer overtones.
Use it on field-recorded sound for interesting sounds, or add to ambient or drones to create unexpected textures. Each parallel looper is a windowed multi(1~12)-tap delay. Each is evenly arranged with a phase shift. You can change the playback speed to create effects like reverse delays and intermediate granular effects.
 Filesize:  95.4 KB
 Viewed:  145 Time(s)
Audiobulb Records : Exploratory Electronic Music
