G2 patch viewer
Page 1 of 1 [11 Posts]
Audio files: 296
PostPosted: Wed Jan 09, 2019 3:24 pm    Post subject:  G2 patch viewer
Subject description: Ian's good old patch viewer restored
I cant find the original page about this .. so here is a new one .. and will sticky it now.
Ian's (ian-s) patch viewer utitlity had stopped working, but Ian sent me some new files .. it seems that all is in order again now.
See : http://electro-music.com/patchviewer/?URL=/forum/download.php?id=46675 for an example
Thanks Ian!
Be sure to to drag the link into the bookmarks .. as indicated on the page .. and then later on:
- for pages with one patch or performance on them click the bookmark to see that patch/performance.
- for pages with more than one patch and or performance .. you can click on the paper click to see that specific one.
Handy for when you dont have your editor around (like on you tablet)!
Jan.
crueltwist
PostPosted: Sun Mar 17, 2024 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
How does this actually work Jan?
I can't work it out, many thanks!
Audio files: 296
PostPosted: Sun Mar 17, 2024 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, it has this link ..
bookmarks bar =>pchview
to get the app into your bookmarks, then when it it is in your bookmarks :
- for pages with more than one patch and or performance .. you can click on the paper clip (on or near the attachment) to see that specific one.
That paper clip got a bit list in my previous post ... your bookmarks must be visible of curse to be able to execute the first point .. [Ctrl+B in some browsers to toggle bookmarkvisibility, and if that is not working there is some menu entry somewhere .. probably :)]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Apr 20, 2024 10:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or you can just use the [see] link in the second column of any G2 patch archive listing on this site. Thanks for adding that Jan.
Audio files: 296
PostPosted: Sun Apr 21, 2024 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I forgot Laughing
Hi Ian Very Happy
nord_balls
PostPosted: Tue May 21, 2024 6:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is the source code for this viewer available?
Audio files: 296
PostPosted: Wed May 22, 2024 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
When you go to the example at : https://electro-music.com/patchviewer/?URL=/forum/download.php?id=46675
Then view the source code in your browser to see :
Code:
   // load required modules from appropriate host
   var lnks = ["NordPch2b.js","nmg2mods.js","parammap.js","main.js","last.js"];
   var host = document.location.host&&"https://electro-music.com/patchviewer/"||"";
   for (var i=0, lnk; lnk=lnks[i]; i++) {
      var st = document.createElement("script");
      st.setAttribute("src", host+lnk);
      st.async = false;
      document.head.appendChild(st);
and to know what other bits are being used.
I think the source would be complete then.
nord_balls
PostPosted: Wed May 22, 2024 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
oh nice, this is actual source not webpack gobbledygook. Thanks!!
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Jun 18, 2024 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just posted the original project folder zip over at Here
Audio files: 296
PostPosted: Tue Jun 18, 2024 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
EDIT : ow um .. i should READ posts first (100 x) Laughing
Cool
Or/And would you want the zip it be on the e-m server?
As in .. coud attach it .. or add it to the wiki .. or have the zip somewhere or .. whatever seems handy?
edit2 : and they are sticky posts already too Shocked
Burp
G2 patch files: 7
PostPosted: Mon Sep 02, 2024 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi ian-s, i tried to contact you through PM but that didn't seem to work. I'm trying to put your patch viewer into an electron app, see: https://electro-music.com/forum/viewtopic.php?highlight=patch+viewer&t=74409. And that seems to work fine. Could be a the start of a new editor. How do you feel if i put your code on a GitHub repo (offcourse mentioning you)?
if you don't know where you're going, you will allways arrive
