 Forum index » Instruments and Equipment » OSX as a music workstation
A really very good ASIO driver for all you Bootcampers
Page 1 of 1 [4 Posts]
PostPosted: Mon Jan 01, 2007 6:02 pm    Post subject: A really very good ASIO driver for all you Bootcampers Reply with quote  Mark this post and the followings unread
I found this rather excellent freeware ASIO driver which works well with the SigmaTel High Definition Audio used on Intel Macs;
http://www.asio4all.com/
I haven't put this in the links section- as I felt that it would be easily overlooked.
jksuperstar
G2 patch files: 18
PostPosted: Mon Jan 01, 2007 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
The ASIO4all is good, but tries to skirt around the problem by using an ASIO front end to a WDM backend driver.
There are SigmaTel ASIO drivers out there (My sony has VERY good drivers, but are released to me by Sony, so I don't know off hand of generic ones). But you should try to find real ASIO drivers if they exist.
PostPosted: Tue Jan 02, 2007 3:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Well yes I know that, but the problem so far that I haven't found a better solution for this Macbook Pro's existing drivers. Audio and stability on this Mac, although it's okay, isn't wonderful either.
suggestions?
PostPosted: Wed Jan 03, 2007 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I swallow my words. ASIO4ALL has died on my Mac Laughing
That'll learn me for getting all worked up and over excited!
