mingrod perfboard layout
Page 1 of 1 [5 Posts]
para
PostPosted: Tue Feb 20, 2007 6:34 am    Post subject: mingrod perfboard layout Reply with quote  Mark this post and the followings unread
childsplay for most of you but i figured i would post it anyway.
the mingrod is a passive analog ring modulator / octave up
http://thesquarewaveparade.com/mingrod.html
steven
sascha neudeck
PostPosted: Mon Feb 26, 2007 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
thanx for your effort Very Happy !
I ordered the parts already and I´m curious how
it will sound.
cheers
sascha
http://www.sascha-neudeck.com
http://myspace.com/saschaneudeck
PostPosted: Mon Feb 26, 2007 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
How do the connections on the jacks go? And which is the output jack? The top one?
para
PostPosted: Mon Feb 26, 2007 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
right i guess i left that out. the top is the out, the bottom right is the source and the left is the mod. but if you only have one thing plugged in either the mod or source then it will route that single input to both the mod and source so you get an octave up.
the jacks should all be facing out, away from center and should be switching for the octave up to work. i'll have to update that when i get a sec. sorry
the output can also be used as the source/making the source the out, but no octave up
samples here http://thesquarewaveparade.com/mingrod.html its pretty nasty
steven
PostPosted: Mon Feb 26, 2007 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this isn't the first time we've had discussions on the passive ring mod circuit. Here was a sample I posted previously.
If anyone can find the actual passive ring mod post, buried in the depths of electro-music.com- that would be great, because I'm buggered if I can find it! Shocked
ACHTUNG!
