assafffff
Posted: Wed Jun 20, 2007 4:05 pm Post subject:
new nmm user Subject description: m |
hi! i'm new my name is assaf from israel and i just bought a nord micro modular and i'm so happy with its abilities comparing to my old synths.
i have one problem (for now)
i downloaded the editor and the update and its work fine but lots of time its getting stuck and i have to close it from the task manager and open again.
anyone know what can it be?
and of course any tips will be good.
assaf. |
Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
Posted: Wed Jun 20, 2007 4:44 pm Post subject:
assaf.
This sometimes happens unfortunately with the NM. If you have another MIDI interface you could try that, or you could try to find newer drivers for the MIDI interface. When you're running under windows XP you can try to set the editor's compatibility mode (by right clicking on the application or a shortcut to the application & going through properties). It can also be a bad MIDI cable.
I might have forgotten something, have look at http://nm-archives.electro-music.com/010_NordModular/018_FAQ/ as well. _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jun 21, 2007 3:03 am Post subject:
Hmm...
I just checked this page, Jan, and we should edit most of the links there...
The FAQ itself is still functional, of course.
Wout |
assafffff
Posted: Thu Jun 21, 2007 4:59 am Post subject:
i have another problem |
my nord wroks ok in the editor but when i open cubase and want to record it its just a big mess.
the cpu usage every couple seconds jump to the end and make noises and the nord does not play the midi notes correct.
anyone? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jun 21, 2007 6:22 am Post subject:
Re: i have another problem |
| assafffff wrote: | my nord wroks ok in the editor but when i open cubase and want to record it its just a big mess.
anyone? |
You are using different ports for the MM(Editor) and Cubase?
It has to by separated systems...
Wout |
assafffff
Posted: Sat Jun 23, 2007 2:26 pm Post subject:
another one :) |
ok i saw on the faq that i should do right click on the editor end choose it to work like win 98 but when i choose it and open the editor it's not finding the pc in and out, when i choose win 2000 or nt the pc in and out are found but the editor keep making problems.
what should id do?
sorry about those questions and the bad english !?  |
cappy2112
Joined: Dec 24, 2004 Posts: 2499 Location: San Jose, California
Posted: Sat Oct 20, 2007 8:05 pm Post subject:
Re: another one :) |
| assafffff wrote: | ok i saw on the faq that i should do right click on the editor end choose it to work like win 98 but when i choose it and open the editor it's not finding the pc in and out, when i choose win 2000 or nt the pc in and out are found but the editor keep making problems.
what should id do?
Did you get your editor workin ok with Cubase?
If you're still having the problem when using the W98 option, try reinstalling your midi drivers again.
Also check to see if there is an uodate for your midi port drivers. |
Colin OOOD
Posted: Thu Oct 25, 2007 5:19 am Post subject:
what should id do?
This is what works for me... maybe it will work for you.
Just run it as a normal XP program (ie. no Win 98 compatability mode) but change your processor scheduling to Programs (in System Properties -> Advanced -> Performance -> Advanced) before you open the MIDI ports in the editor; then when the editor has found the NM1, switch it back to Background Services. You will need to do this each time you start the editor - or keep your PC's processor scheduling set to Programs if you don't use it for audio. |
cappy2112
Posted: Thu Oct 25, 2007 6:28 am Post subject:
| Colin OOOD wrote: | | or keep your PC's processor scheduling set to Programs if you don't use it for audio. |
XP uses the Programs setting by default. I've often wondered what the system performance would be like if I used Background Services instead of programs, but never tried. |
Colin OOOD
Posted: Thu Oct 25, 2007 6:51 am Post subject:
| cappy2112 wrote: | | Colin OOOD wrote: | | or keep your PC's processor scheduling set to Programs if you don't use it for audio. |
ASIO and other audio drivers work as background processes so making the switch to Background Services is the single most effective tweak for audio you can make to an XP system. If you make music on your computer with this set to Programs, switching to Background Services will probably transform your music-making. |
assafffff
Posted: Sat Oct 27, 2007 2:53 am Post subject:
hi |
thanks for all the help i fix it by using a new midi interface, i needed another midi interface for a new synth so i bought an esi m4u and it works smooth.
the problems were with emu 1820m midi.
thanks, assaf. |
