MicroNord USB Mod
Page 1 of 1 [15 Posts]
wesen
PostPosted: Fri Dec 28, 2007 7:00 am    Post subject: MicroNord USB Mod Reply with quote  Mark this post and the followings unread
I've modded my micromodular with a USB-MIDI circuit I built. It's actually just the first try at a mod I want to do. This one just puts a USB MIDI board connected to the PC midi ports into the Nord. I'm not very skilled at crafts so my USB connector is a bit off, but it works nicely. As I have written the software on the MIDI circuit, I can actually send custom Nord editor messages to the Nord, for example to switch Key Scale modules or stuf flike that. So the second version of this mod will feature a triple midi interface connecting to both PC and MIDI ports of the nord, which will "filter" the inputs on the MIDI side (so you can still connect a sequencer to the MIDI ports), and for example switch sequences on a NOTE event, or make custom patch groups, etc... I already have the circuit working, but I need to make a smaller board to fit into the nord.
You can see pictures here:
http://bl0rg.net/~manuel/nord-usb/
PostPosted: Fri Dec 28, 2007 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Wesen- that's cool!
Any more info on the circuit?
ACHTUNG!
wesen
PostPosted: Fri Dec 28, 2007 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
It's a board with atmega8 and PDIUSBD12, and that's about it. On the photos you can see the pdiusbd12, the atmega8 is on the other side.
I can't really release the software though. To make you all lust for the triple MIDI version, it can also do MIDI Clock sync for the NM1 Smile
PostPosted: Fri Dec 28, 2007 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Confused
Why not?
ACHTUNG!
wesen
PostPosted: Fri Dec 28, 2007 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm developing the software commercially. I could provide flashed boards though. I'll look into this. I'm really not comfortable with modding other people's gear though, being the clumsy hacker I am.
PostPosted: Fri Dec 28, 2007 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm quite at home (ie qualified) in doing my own soldering you know Idea Very Happy
It's the one thing right now that puts me off plugging in my Micro (more to do with finding a midi lead that works!!). A little kit like this would be spot on.
You know we have a comprehensive DIY section here? I'm sure that there would be many who would purchase from you too, Because it would be easy to rack a MM and use it within an existing analogue modular section as a highly versatile module (which it is- and greatly underrated too Wink )
Tom
ACHTUNG!
wesen
PostPosted: Fri Dec 28, 2007 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes nice I see what I'll can do. The "simple" boards are ready, I'll order a few next week and solder the chips on and send them to people who want for a little bit of money to cover costs.
Funky40
G2 patch files: 5
PostPosted: Fri Dec 28, 2007 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Tom
yes, agree ! absolutely underrated.
I only use my NM1 as that versatile module for my anlaog modular.
Allways as a midi to trigger converter,
or gate sequenzer,
sometimes as a multi VCO source.
And sometimes as an VCA/Envelope combination with that cool Velocity response, but then with that loss on the bottom end which the clavia modulars have
Waht does this mean exactly ?
i would need midiclock sync for the LFOs
PostPosted: Fri Dec 28, 2007 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
or gate sequenzer,
Actually the list of possibilities is huge! It could also be really easy to program Cynthia's Zero Oscillator into the Micro too.
I've also got 5+ note polyphony with FM to boot from it also Very Happy
ACHTUNG!
PostPosted: Fri Dec 28, 2007 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes, you know that Midi sync on the LFO's IS possible you know. Someone figured that out- I remember.
ACHTUNG!
wesen
PostPosted: Fri Dec 28, 2007 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh lol
http://nm-archives.electro-music.com/010_NordModular/014_Interesting_Threads/Folder/LFO&MidiClock/LFO&MidiClock.htm
I guess I could have checked the archives before building my own external solution generating nord editor messages.
Burp
G2 patch files: 7
PostPosted: Sat Dec 29, 2007 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
WOW thats a nice mod for the micro. Smile
if you don't know where you're going, you will allways arrive
JLS
G2 patch files: 316
PostPosted: Sat Dec 29, 2007 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi All
This is my MicroModular modification - im using this long time and working fine Smile
- base is Midiman usb two channel midi ports A and B ( drivers working all OS on midiman site )
- porta A use like editor
- port B use like midi connectin for keyboard and sequencer
My future idea is:
- made rack version for my other synth rackmount
- digital in/out convertor for audio
Kamil
 Filesize:  87.21 KB
 Viewed:  284 Time(s)
PostPosted: Sat Dec 29, 2007 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
wesen wrote:
Oh lol
I wouldn't give up though, because the work around still requires extra patch load. Having some hardware to do this and adding usb will be very cool you know Smile
ACHTUNG!
cappy2112
PostPosted: Sun Dec 30, 2007 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tom
I recently bought a microcontroller board kit, but I haven't used a soldering iron in so long, I've really gotten rusty.
