Static Strobe Emitter
Audio files: 243
Posted: Mon Mar 03, 2008 7:29 am Post subject:
8-Bit NES Chipmusic Subject description: Let the chips be with you! |
This was a pretty popular console back in the 1980s.
For those unfamiliar with what it is can go into this wikipedia link
http://en.wikipedia.org/wiki/Nintendo_Entertainment_System
The soundchip specs are (directly from wikipedia):
The NES board supported a total of five sound channels. These included two pulse wave channels of variable duty cycle (12.5%, 25%, 50%, and 75%), with a volume control of sixteen levels, and hardware pitch bending supporting frequencies ranging from 54 Hz to 28 kHz. Additional channels included one fixed-volume triangle wave channel supporting frequencies from 27 Hz to 56 kHz, one sixteen-volume level white noise channel supporting two modes (by adjusting inputs on a linear feedback shift register) at sixteen preprogrammed frequencies, and one delta pulse-width modulation channel with six bits of range, using 1-bit delta encoding at sixteen preprogrammed sample rates from 4.2 kHz to 33.5 kHz. This final channel was also capable of playing standard pulse-code modulation (PCM) sound by writing individual 7-bit values at timed intervals.
I will convert all tracks to MP3 for easiest playback.
However if i gets asked to give away a source to be compiled code for
replaying on a real NES hardware i can provide that for each individual track.
Cheers! |
Audio files: 243
Audio files: 243
Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
Posted: Mon Mar 03, 2008 3:24 pm Post subject:
Aah .. I had been missing that ... good to hear that the music still works  _________________ Jan
Audio files: 243
Drone
Joined: Feb 06, 2008 Posts: 59 Location: The Great White North
Posted: Tue Mar 04, 2008 8:32 am Post subject:
Hey Static Strobe Emitter, nice to see you back & thanks for sharing ! _________________ It is at least ten times more difficult to get a good synthesizer sound than on an acoustic instrument. - Giorgio Moroder |
Posted: Tue Mar 04, 2008 9:38 am Post subject:
| Yes, these are great! Glad to see you still in action! |
Housefly
Posted: Sat Apr 12, 2008 7:44 am Post subject:
i had one of those, well actually it was a sega master system 8 bit. i still have a thumb (the right one) that is disformed from playing too much...
luckily strobe didn't compose the tunes back then... or the thumb would've dropped off completely |
Audio files: 243
Audio files: 243
Audio files: 243
Posted: Mon Jun 15, 2009 1:31 pm Post subject:
Nice ones strobe! _________________ Jan
Audio files: 243
opg
Joined: Mar 29, 2004 Posts: 954 Location: Berkeley, CA, US
Posted: Wed Jan 20, 2010 1:11 pm Post subject:
Re: :OO Subject description: hi there |
| Static Strobe Emitter wrote: | This tune started out just as an experimental tune,
where i basically wanted to see how far i could push bankswitching
with the NSF tune compiler.
also taxing on my own sample switching skills,
since the streamed samples can only use 16kb per bank
(hardware design on the NES) it turned out
to be a nightmare to make it sound as seamless as possible.
But here it is
Many thanks to JSR who made the custom compiler, and listening to my inquiries and made modifications i begged for.
Without him, this frankenstein tune wouldnt have been possible for me. |
Aww yeah, that kicked ass. NICE WORK! _________________ One Player Game | OPG on SoundCloud |
