Nord Wave Slot A and B software update?
Page 1 of 1 [5 Posts]
Ruud
PostPosted: Sun Apr 27, 2008 11:55 pm    Post subject: Nord Wave Slot A and B software update? Reply with quote  Mark this post and the followings unread
I think I have to bring my Wave back to the music store...
When I press slot B and try to search a sound it jumps back to slot A.
Any Nord Wave users have the same problem? Confused
nordragious
PostPosted: Mon May 05, 2008 11:27 am    Post subject: slot B Reply with quote  Mark this post and the followings unread
Press and hold the Slot b button while you turn the main program encoder... If you keep the slot b button pressed you will toggle tru the A-B slots in each of the "programs" (wich can consist of either a A, B, A+B slot combination)
Slot a+b does not work excactly as on the Leads in the wave, it's a "mix" of performance mode and program mode.... why i don't know.
Submenu - No thanks.. Let's tweak some knobs!
Ruud
PostPosted: Tue May 06, 2008 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Oké I'll have a try tonight.
I hope that solves the problem.
I still haven't been so far to bring it back to the store cause every
time I put the power on I start playing and forget the time!
Thanks nordragious!
nordragious
PostPosted: Tue May 06, 2008 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome:)
I would like to see a "memory" function for this because if you "dial in" a slot from the "A-B" program slots and for some reason dont get satisfied and wants to continue your search it starts over at 1.1 slot A again... wery annoying when you are trying to make a new "performance"...
plasmid
PostPosted: Wed May 07, 2008 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
nordragious wrote:
You're welcome:)
It's completely amusing. Wth was Clavia thinking.
