DS7 Stuff
Page 1 of 1 [4 Posts]
christiancoler
PostPosted: Tue May 27, 2008 4:10 pm    Post subject: DS7 Stuff Reply with quote  Mark this post and the followings unread
Anyone feel like explaining to a noob how to make about 5 ds7s and connect them so I have a basic electronic drumset? (where to get PCBs or PCB layouts and all other documentation would be nice, I found that schematic, but dont know how to make that to a pcb). Even advice on stripboarding it would be nice.
Christian
toybox
PostPosted: Tue May 27, 2008 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.electro-music.com/forum/topic-6386.html
pcbs are in their some ware good place to start . to make pcb just look it up on you tube and instructables.com some good tutorials. hope i gave you some help Very Happy
mY MusIc
http://www.myspace.com/toyboxbastard
christiancoler
PostPosted: Tue May 27, 2008 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I got another question, kind of off topic, but would it be hard to make a drum synth that contains some memory that would store samples, and would play those samples when triggered? (i guess this is more of a digital synth, but I would still want the potentiometers to tweak pitch and all that stuff)
creatorlars
PostPosted: Wed May 28, 2008 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I've built a 16 channel eDrum Trigger-to-MIDI box before (edrum.info), and several analogue drum modules (including two DS7's.) The eDrum and DS7 are both great projects. If you're new, the DS7 is a good one. The eDrum was my first electronics diy project, and it was not easy at all -- but I finished it eventually. Smile You can order DS7 boards from Marc Bareille or check out the thread here for some PCB layouts (I made the LM13700 version.)
I wouldn't mess with sampled drum modules - maybe just get a sampler w/multiple outs (not sure what model would be best), gut it, and install it in the same case with some analogue filters, etc? That could be cool. I really love the Alesis SR-16, as far as cheap sample-based drum machines go. Right now I have a rackmount Ensoniq Mirage, which is kind of an archaic beast -- but it's the "digital component" of my rig, which I use for any kind of drum/percussion sampling that needs to happen. Gets the late 80's EBM/Skinny Puppy grit that I like. Smile Or you could find toy keyboards/drumsets and try to gut and rewire those for trigger inputs or MIDI...
That said, there is also the Alpha Drum... I'll attach the documentation I have. It was a DIY rom-sampled drum module, I think. I haven't looked into it much, but would love to build one at some point.
Alpha Drum Article.pdf
 Filename:  Alpha Drum Article.pdf
 Filesize:  141.71 KB
 Downloaded:  244 Time(s)
