ne570/571 compressor circuits?
Page 1 of 1 [8 Posts]
loss1234
PostPosted: Tue May 27, 2008 5:33 am    Post subject: ne570/571 compressor circuits? Reply with quote  Mark this post and the followings unread
just got some ne571's in the mail and i want to try and make some compression circuits. the datasheet is too vague. anyone know of any good circuits using this chip?
thanks
CJ Miller
PostPosted: Tue May 27, 2008 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I've never had any of them myself, as of yet. I do have a booklet from Thomas Henry, called "Making Music with the NE570 Compander", which looks cool. About 20 pages of schematics and lab notes from somebody who has spent some time with these. Which reminds me, if you do some web searches for NE570 you might find more info, I wasn't even aware of the SA570. Another idea is to do a google image search for NE570 and sort through the jpegs it throws you.
I know I've seen these in old samplers and sampling drum machines. Only schem I have somewhere is a Japanese vocoder project which uses them, but I'll need to find it. I'm sure that there is a good amount of old applications info for these out there somewhere.
marr
PostPosted: Sat Jun 14, 2008 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
PAiA vocoder uses them.
danielwarner
PostPosted: Sat Jun 14, 2008 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Not a compression circuit, but the Craig Anderton Rocktave circuit calls for a 570 or 571
ericcoleridge
PostPosted: Sat Jun 14, 2008 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
This chip is also used to compress the incoming signal on the Korg SE500 'Stage Echo' tape delay. I think after the signal is processed, delayed, etc., it's then expanded again before being sent to the output. I think it's used here for noise reduction. I have own one of these tape delays, and have the schematic.
Its probably used on the other Korg tape echo too, the SE300.
loss1234
PostPosted: Sat Jun 14, 2008 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
the rocktave..i have looked a that before and forgot it had a 571
great
whats the korg like?
Luka
PostPosted: Sun Jun 15, 2008 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
hey loss if you decide to use the chip for something else
there is a nice compressor in this circuit that uses the THAT chips
it is from the "boxotrix"
http://burnit.co.uk/sdiy/images/boxotrix/schematic_compressor_small.gif
actually i think seb has some pcb's left
this is a cool machine
i cant wait to build mine
problemchild
melbourne australia
mediatechnology
PostPosted: Tue Aug 12, 2008 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys there's this old series from TAA and Jung:
http://www.picocompressorforum.com/forum/php/viewtopic.php?f=12&t=150
On Semi still make them:
http://www.onsemi.com/pub_link/Collateral/NE570-D.PDF
