ilSignorCarlo
Posted: Thu Jul 03, 2008 11:56 am Post subject:
ChucK, GUI and Processing |
is there any way to know if ChucK can work with a particular graphical environment?
I mean, I'd like to bind ChucK to a GUI, but I am not sure if it's gonna work. Are there requisites that a programming language or a GUI should have to be compatible with ChucK?
Or, in general, how should I test it?
I've found this environment: Processing.
It seems pretty cool and I think it would be great to use in combination with ChucK. Just not sure that it is possible.
What do you think? _________________ Self-referential phrases, like this one, are not so funny or good for a forum signature. |
Inventor
Audio files: 267
Posted: Thu Jul 03, 2008 12:48 pm Post subject:
Some people have attached GUI's to ChucK in the past, but as far as I can tell it's a true DIY thing because it is unlikely that others will go through your particular setup process to get your GUI working, especially when ChucK has a GUI that's due for arrival to the Linux and PC versions anytime now. We've been waiting some time for "anytime now" to roll around but it is on the next release, thankfully.
So although it may seem cool to add a GUI to ChucK, you must realize that the probability is that only you will ever use it. At least that's what happened in the past when others attempted this. So the best thing to do, IMHO, is wait for the ChucK GUI to finally arrive, sigh. Wish I could be more positive about it... _________________ "Let's make noise for peace." - Kijjaz |
Kassen
Posted: Thu Jul 03, 2008 1:44 pm Post subject:
Processing makes perfect sense to me for this. As it's Java based the syntax isn't too different (less to learn!), it's also build as a educational intro to programming and graphics, it eats OSC, it's as cross-platform as ChucK...
As inventor points out; sharing your code (getting others to run it) will be harder but if you just need something for yourself I'd say "go!". _________________ Kassen |
ilSignorCarlo
Posted: Thu Jul 03, 2008 4:09 pm Post subject:
Kassen wrote: |
As inventor points out; sharing your code (getting others to run it) will be harder but if you just need something for yourself I'd say "go!". |
Yes, I understand this. But for a project I have in mind I think I need a GUI. Anyway, in this moment I'm a newbie with ChucK.
What can I try to do just to test if a GUI works well with ChucK? How am I supposed to bind, for example, the creation of a graphical object to a ChucK object?
Sorry if the question sounds stupid. _________________ Self-referential phrases, like this one, are not so funny or good for a forum signature. |
Kassen
Posted: Thu Jul 03, 2008 5:25 pm Post subject:
No problem, we were all newbies at one point; I myself hardly know anything about the details of Processing.
I think you should look into OSC (Open Sound Control). You could make objects (classes) in ChucK that would also send out a OSC message to Processing calling for the creation of a interface as they get initiated. From there on it would be messages back& forth. You'd have to design a little protocol that would depend on your needs but it sounds doable if advanced to me. _________________ Kassen |
Inventor
Audio files: 267
Posted: Thu Jul 03, 2008 6:26 pm Post subject:
Don't let me discourage you, if you want a great ChucK GUI then I agree with Kassen, do whatever you want to! ChucK is designed to be flexible and friendly with other applications through things like OSC. I myself have not yet learned anything about OSC and it's a bit of a mystery so I can't help you, but I wish you the best of luck and look forward to some screenshots. I wish there was some decent ChucK-side documentation of OSC, but I haven't found any yet. _________________ "Let's make noise for peace." - Kijjaz |
ilSignorCarlo
Posted: Fri Jul 04, 2008 1:36 am Post subject:
ok, with some more search I've found that actually someone already used Processing with ChucK, using OSC to make them communicate.
Do you know if there exist a starting tutorial or something about OSC? _________________ Self-referential phrases, like this one, are not so funny or good for a forum signature. |
Inventor
Audio files: 267
Posted: Fri Jul 04, 2008 3:29 am Post subject:
Here is one:
http://opensoundcontrol.org/topic/151
I did a google search on "open sound control tutorial" and found several others. If you figure it out, come back and tell us how it works. I haven't invested the time to learn OSC because there is little documentation of it on the ChucK site. _________________ "Let's make noise for peace." - Kijjaz |
dewdrop_world
Joined: Aug 28, 2006 Posts: 858 Location: Guangzhou, China
Posted: Fri Jul 04, 2008 8:19 am Post subject:
If you're looking for the usual types of sliders, buttons, pop-up menus etc., another very good option is SwingOSC. It doesn't do everything processing can do, but it might save some effort because you would just have to implement the existing OSC protocol in ChucK -- no need to design your own brand-new protocol, and implement it in both ChucK and Processing.
The OSC protocol is documented here... the trickier thing is knowing which Java objects to instantiate and how to manipulate them. So I guess if you don't know swing classes, this might not be so much help.
Supercollider uses this for cross-platform GUI compatibility and it's working very well.
James _________________ ddw online: http://www.dewdrop-world.net
sc3 online: http://supercollider.sourceforge.net |
ilSignorCarlo
Posted: Fri Jul 04, 2008 9:40 am Post subject:
dewdrop_world wrote: | If you're looking for the usual types of sliders, buttons, pop-up menus etc., another very good option is SwingOSC. |
Mmm, I was searching something more flexible. I need to create objects, move them, connect objects to other objects...
Make them blink, faster or slower, depending on a metronome, for example. So I thought I could do all this with Processing.
Quote: | Supercollider uses this for cross-platform GUI compatibility and it's working very well. |
Yes, I know Supercollider, but I think I prefer using ChucK. _________________ Self-referential phrases, like this one, are not so funny or good for a forum signature. |
dewdrop_world
Posted: Fri Jul 04, 2008 12:16 pm Post subject:
OK, definitely Processing is a better fit for that.
(I wasn't trying to convince you to use SuperCollider btw... just pointing out an area where SwingOSC is being used successfully.)
ilSignorCarlo
Posted: Sat Jul 05, 2008 3:40 am Post subject:
dewdrop_world wrote: | OK, definitely Processing is a better fit for that.
James |
I was starting studying SuperCollider, but then someone pointed me to ChucK and it just seemed cooler to me
Anyway, I've found this about ChucK and Processing:
http://visiblearea.com/blog/pub/VisibleArea/ProcessingandChucK/readme.txt _________________ Self-referential phrases, like this one, are not so funny or good for a forum signature. |
Kassen
Posted: Sat Jul 05, 2008 5:27 am Post subject:
Considering that Swing OSC is a Java library, wouldn't you be able to load it in Processing anyway if you'd feel the need? _________________ Kassen |
Posted: Sat Jul 05, 2008 4:31 pm Post subject:
Didn't see this thread until now. I'm actually tinkering with a Java GUI for arranging samples on the fly, that I intend to have communicate with a ChucK program using OSC. So the Java app does all the fancy graphics stuff and calculates times, and ChucK does the sharp timing. Most of the crucial stuff in the Java app is in place, and I have working OSC communication (using my own home-brewed UDP implementation). Now I only need to get the ChucK stuff in place.
The main reason for me doing it this way is because I wanted to try out SWT in Java and just generally experiment a bit. I might be able do this with MAUI instead. It would be interesting to try running the graphical frontend on a different computer than the sound generating one as well.
Anyway, if this sounds interesting in any way, I'll probably have something to share soon.
Acoustic Interloper
Joined: Jul 07, 2007 Posts: 2073 Location: Berks County, PA
Audio files: 89
Posted: Mon Jul 14, 2008 6:05 pm Post subject:
Antimon wrote: |
I've been writing a lot of SWT code this year for my job, extending Eclipse for a DSP toolset, just finishing up a grapher for run-time costs in an instruction simulator for a DSP. When it comes to GUI programming, I'd WAY rather use Tk with Python (a.k.a. Tkinter) or Tcl than use SWT. Tk lets you attach symbolic tags to graphical elements on a canvas or in a text widget and manipulate sets of elements together. I've used it for the Python-to-ChucK (or SC or Max/MSP) chess game GUI here. SWT, in contrast, is lower level, for example you have to prep a bunch of data structures for painting and then do the actual paint in your code whenever the window is exposed, resized, etc. Not that SWT is bad, just that it operates at a much lower level. The only issue with Tk is that its widget set is somewhat dated, e.g. no toolbars per se, but it's a lot handier to program, in my opinion.
EDIT: This program works on multiple machines on a LAN, although I think for best results the Python algorithmic generator should be on the same machine as ChucK; less latency and overhead that way, and the Python program does not eat much CPU.
The GUI chessboards, though, can be distributed across the LAN, so players can sit on different machines when playing their chess games. _________________ When the stream is deep
my wild little dog frolics,
when shallow, she drinks. |
Posted: Tue Jul 15, 2008 1:50 am Post subject:
Acoustic Interloper wrote: | Antimon wrote: |
I've been writing a lot of SWT code this year for my job, extending Eclipse for a DSP toolset, just finishing up a grapher for run-time costs in an instruction simulator for a DSP. When it comes to GUI programming, I'd WAY rather use Tk with Python (a.k.a. Tkinter) or Tcl than use SWT. Tk lets you attach symbolic tags to graphical elements on a canvas or in a text widget and manipulate sets of elements together. I've used it for the Python-to-ChucK (or SC or Max/MSP) chess game GUI here. SWT, in contrast, is lower level, for example you have to prep a bunch of data structures for painting and then do the actual paint in your code whenever the window is exposed, resized, etc. Not that SWT is bad, just that it operates at a much lower level. The only issue with Tk is that its widget set is somewhat dated, e.g. no toolbars per se, but it's a lot handier to program, in my opinion. |
I've posted that project here: http://electro-music.com/forum/topic-27609.html
Moving from swing to SWT was enjoyable anyway. Everybody's talking about Python nowadays, so should probably check it out. I'm starting to become a bit set in my ways.
