Voltage indicator
Page 1 of 1 [12 Posts]
PostPosted: Tue Oct 28, 2008 7:37 pm    Post subject: Voltage indicator
Subject description: More than a bi-colour but less than a bar?
I'm trying to do a simple voltage indicator. Maybe just three LEDs. I need low parts count, but I can afford an op-amp already on it. (I actually need 3, and the design has 3 spare op-amps waiting)
Do I have to go for comparators?
I've got some LM3914s, but I want to save them for a couple of 5-pulsers. Besides, I don't have room for that many LEDs.
I'd like the mid one to cover +/-1V and the outer two to cover >+1V and <-1V.
Any ideas?
Tim Servo
PostPosted: Tue Oct 28, 2008 10:29 pm    Post subject: Voltage indicator Reply with quote  Mark this post and the followings unread
Hey Unk,
You might be able to rig up a chain of op-amps configured as comparators. Each comparator triggers at a slightly higher level, giving you a 'bar graph' effect as the input voltage rises. Here are a couple of examples I found:
http://www.ecelab.com/circuit-simple-led-voltmeter.htm
http://www.elecfree.com/electronic/bargraph-voltage-indicator-by-lm339/
This one only uses a single op-amp
http://www.elecfree.com/circuit/Meter-test-circuit/bargraph-light-meter-by-ic-741/
This one uses transistors, and has one stage enable the next
http://electronicdesign.com/Articles/Index.cfm?AD=1&ArticleID=6246
And a whole bunch of good info / theory on the op-amp type
http://www.opamp-electronics.com/tutorials/the_operational_amplifier_3_08_03.htm
Hope this helps!
Tim (if you put it upside-down, is it a hparg rab?) Servo
Inventor
Audio files: 267
PostPosted: Tue Oct 28, 2008 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
A divider/ladder type structure as shown in the above links is a good start. Also, why not utilize the fact that LEDs have different knee voltages? A red LED is only 1.7V or so, so that could be your +/- 1V indicator (with gain of 1.7), and the other color LEDs would turn on at a higher voltage. That would be more of a parallel approach. In fact, if you don't need buffering then the opamp itself may not be necessary - depends on whether you have a low-impedance source.
something like this:
Code:
----R------R-----
       D        D
where the first D is blue and the second is red, and each D represents a pair of side-to-side diodes (one up, one down). Might werk gewd!
BOB-SNARE
PostPosted: Tue Oct 28, 2008 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or something like this...maybe use the opamp to level shift/amplify.
PostPosted: Wed Oct 29, 2008 12:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks heaps everyone for all the great ideas and links. I'll keep you all updated on my progress. Very Happy
urbanscallywag
PostPosted: Wed Oct 29, 2008 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Three ideas:
A microcontroller sampling the voltage, (re)quantizing the analog value and turning on appropriate LEDs (as few/many as you'd like).
A microcontroller sampling the voltage and PWM output to an LED.
An analog voltage controlled PWM circuit.
PostPosted: Wed Oct 29, 2008 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm,
I think the microcontroller ideas would be a bit too complicated for what I want, but I'm intrigued by the PWM idea. How do convert that to a 3 LED indicator?
urbanscallywag
PostPosted: Wed Oct 29, 2008 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking of controlling a single LED with analog PWM like in the microcontroller PWM in the suggestion above it. Embarassed
A bicolor LED with PWM could be really cool. The color would dictate polarity, the intensity would be the magnitude.
Inventor
Audio files: 267
PostPosted: Wed Oct 29, 2008 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tell you what would be trick, would be to use a bilateral current source. This circuit appears in National Semiconductor's Linear Applications Handbook and requires only one opamp and five resistors. You apply an input voltage and the output current is proportional to the input current, magically in *both* positive and negative directions.
Then you could just put side-to-side diodes on the output and the intensity of the diodes would directly track the input voltage, with one diode for positive and the other for negative. That's because, as you surely know, the intensity of an LED is proportional to its current.
I have the page opened up and can give you the info but it's detailed. If you want to use this circuit I'd suggest obtaining the PDF file of AN-29 from www.national.com if you are interested. I can help you find this file if you cannot find it (I think so anyway). Cheers!
frijitz
Audio files: 54
PostPosted: Thu Oct 30, 2008 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funny you should bring that up. I needed a bipolar current source last month, while trying out a crazy ribbon controller scheme. I saw that AN-29 circuit, but I didn't see any advantage of it over the standard Howland circuit. So I went with the Howland. It worked great! There are always warnings about needing carefully matched resistors, but for what I was doing just taking 1% resistors out of the drawer worked just fine. That's a slick idea you have, using a bipolar I source for an indicator.
Ian
Inventor
Audio files: 267
PostPosted: Fri Oct 31, 2008 12:18 am    Post subject: Reply with quote  Mark this post and the followings unread
What does the Howland circuit look like?
frijitz
Audio files: 54
PostPosted: Fri Oct 31, 2008 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.national.com/an/AN/AN-1515.pdf
(Google is your friend.)
Ian
