andrewF
Rykhaard
Posted: Fri Aug 29, 2008 8:48 pm Post subject:
Re: Bridechamber : CGS Analog Computer |
It could possibly be Comparator Out, going by a preset level to compare against with LO / HI out judged from the Input voltage. |
neandrewthal
Posted: Fri Aug 29, 2008 11:10 pm Post subject:
Well, it says there is a gate converter on the panel so I'm assuming it's that. _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Sat Aug 30, 2008 2:09 am Post subject:
| This is a handy module! |
sduck
Posted: Tue Oct 28, 2008 8:07 pm Post subject:
| I bought one of the panels for this and the pcb's, and it's mostly put together now. Still waiting on some more jacks - this one takes a lot of them! A ton of wires to connect soon... |
Luka
Rykhaard
Posted: Tue Oct 28, 2008 9:58 pm Post subject:
| Luka wrote: | i am about to grab this too
is it all on one pcb sduck?
or is the just the selection of cgs pcbs? |
I just had a gander at cgssynth and I didn't see 'Analog Computer'. My guess is that bridechamber, put it together.
Ah well. I've been pondering putting together a HUGE logic collection. I think I'll just stick with my plan.  |
Luka
sduck
BananaPlug
Posted: Wed Oct 29, 2008 6:41 am Post subject:
| Let us know what you think of the analog shift register. Those often are less than ideal. Typical problems: Less than instantaneous capture of the new level (slight portamento), leaky hold (voltage slowly sinks), level differences from stage to stage (e.g. one output always a little higher or lower than others). The circuit description at cgs looks pretty good. |
sduck
Posted: Mon Nov 03, 2008 7:45 pm Post subject:
I'd like to let you know what I think about the asr, but that's the one part of it that doesn't work. I'm going to have to do some troubleshooting with it. My first guess is the four big caps - I was just guessing with those, and am pretty sure I've got the completely wrong kind in there (I can't remember what they are offhand). Any suggestions for what to use for these?
In the schematic, they are labeled cx - and Ken's note - "The capacitors specified as CX on the circuit board and diagram are the S&H capacitors and as such should be high quality low leakage sorts, such as polypropylene. The value of them will depend on the speed at which you intend to run the unit. The larger the capacitor, the lower the maximum speed at which it will run, but the longer it will be able to hold the voltage without drooping. 47n is probably the smallest that should be used, though drooping becomes quite noticeable at slow speeds. It may be possible to go as high as 470n for really slow operation, though this will somewhat limit the maximum speed (see the notes below). "
In other words, if anyone's gotten this to work well, what caps did you use? |
eyjolv
Posted: Fri Nov 14, 2008 3:28 pm Post subject:
Hi.
| sduck wrote: | | In other words, if anyone's gotten this to work well, what caps did you use? |
I just built the ASR. I used the parts kit that I got from Bridechamber. That was 47n capacitors.
Unfortunately mine doesn't function properly; there are some issues:
- the outputs have one stage that doesn't work; they give a voltage gliding upwards to 10-15v regardsless of input. The other three stages work.
- the outputs are about 2 semitones offset
I guess I did some mistake assembling it. Or one IC is bad. What is wrong with yours? |
Luka
Phillip Jeffries
Posted: Sun Nov 23, 2008 1:17 am Post subject:
sduck
Posted: Sun Nov 23, 2008 12:02 pm Post subject:
| Cool! Umm... - what is it? And where can I get one? |
Phillip Jeffries
sduck
Posted: Sun Nov 23, 2008 6:15 pm Post subject:
| Ok. General purpose, check. Computer, check. Lots of knobs and 1/4" jacks, check. Hard to read, inscrutable labels on knobs, check. Lots and lots of blinky lights, double check. But does it handle +10v? Hmmm? And where's the clock in? Hmmm? |
sduck
Posted: Thu Dec 11, 2008 7:28 am Post subject:
Ok, a follow up. The way I put mine together, it was going to be a huge pain to remove it, replace the parts, and then remember which wire went where, so I just did a complete board transplant. Bought a new pcb and parts - cost around 20$. Built it up, and then was able to do the whole replace in one sitting, so no problem with remembering wiring issues. And it works now!
I have the same issues as others have reported, namely, the voltages coming out of the various stages aren't the same as the one I'm putting in. They're pretty close, though, so it's just a matter of tuning the affected vco if that's an issue. I'm not getting drift or anything, although I haven't tried it with really slow clock speeds yet. My guess is that this is an issue with the type of caps used - they're what's storing the values, right? |
