The DoubleDeka Ultrasonic VCO
Page 4 of 6 [145 Posts]
frijitz
Audio files: 54
PostPosted: Thu Jan 15, 2009 8:33 pm    Post subject:
Subject description: The bus has just rolled in!
Good news ... The DoubleDeka is now for sale at bridechamber.com!
Ian
drapdap
PostPosted: Fri Jan 16, 2009 5:29 am    Post subject:
http://www.bridechamber.com/bridechamber.com/F%20DoubleDeka.html
Not cheap, but f+++! A dream came true, a hardware wavedraw osc.
Congratulations on that Ian, you are massive!
I wanted to ask about the sliders, - it might have been mentioned earlier-
but how many kiloOhm sliders are we talking about?
róbert
frijitz
Audio files: 54
PostPosted: Fri Jan 16, 2009 10:19 am    Post subject:
drapdap wrote:
I wanted to ask about the sliders, - it might have been mentioned earlier-but how many kiloOhm sliders are we talking about
Not critical, since they are used as voltage dividers. Nominally 10k. Anything 2k - 50k should be fine.
Ian
pristak
PostPosted: Fri May 08, 2009 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, my full kit is finally in the mail. I've been intending to order this for a while.
Is anyone else working on this one? I think this will jump ahead on my list since most of my other projects are waiting on backordered parts.
pristak
PostPosted: Thu May 14, 2009 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I made a serious dent in this project last night. There wasn't much interest on here, so my pics and progress so far is here http://www.muffwiggler.com/forum/topic-5095.html
pristak
PostPosted: Thu May 28, 2009 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had some more progress on this. The pic's are up on the muffwiggler site.
pristak
PostPosted: Sun May 31, 2009 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished. It worked fine first try. I still need to calibrate it and reverse the wiring on the Sync switch, but everything worked first try.
dave_3283
PostPosted: Mon Jun 01, 2009 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone know the size on the linear pot PCB? I've been doing 4u Serge-ish panels and would like to figure out if I can make this project fit...
frijitz
Audio files: 54
PostPosted: Mon Jun 01, 2009 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy Glad to hear it! Any chance for some mp3's?
Ian
frijitz
Audio files: 54
PostPosted: Mon Jun 01, 2009 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I do. Very Happy
4"x6.6"
Ian
Coriolis
PostPosted: Mon Jun 01, 2009 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pristak, that is downright nice! Sigh..I'll never get that to fit in my panel format...
C
pristak
PostPosted: Mon Jun 01, 2009 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I won't likely have a chance to get serious mp3's together for a while. I am reorganizing my studio and don't have all the power cabling and placement worked out. I get married very soon as well so time is limited right now.
I may be able to put up a quick demo sometime soon, but I've done that before and been real disappointed when I listened back later. We'll see.
frijitz
Audio files: 54
PostPosted: Tue Jun 02, 2009 8:15 am    Post subject: rounded Saw demo Reply with quote  Mark this post and the followings unread
There is some discussion on the sdiy list about what a Saw run through a Sin shaper would sound like. I set up the DD to produce both a Saw and a rounded Saw so folks can hear the difference. The rounded Saw is closer to a Square wave than a straight Saw is, so it has relatively fewer even harmonics. Of course, these are ten-step approximations, but that doesn't matter too much in making the comparison. On the mp3, the rounded Saw is first and the regular Saw is second.
Ian
sawsinsaw.mp3
 Filename:  sawsinsaw.mp3
 Filesize:  335.63 KB
 Downloaded:  1456 Time(s)
pristak
PostPosted: Sat Jun 06, 2009 9:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's calibrated to the best of my abilities with what I have available. Ie, it stays in tune according to my guitar tuner across the octaves.
Samples are up on the muffwiggler site.
http://www.muffwiggler.com/forum/post-71331.html#71331
lexvortex
PostPosted: Sun Jun 07, 2009 2:03 am    Post subject: Problem with DDeka Reply with quote  Mark this post and the followings unread
Hi Ian,
I just finished building two of these Smile They sound awesome!! I am however having a slight problem with the second one I built, it tracks well in the lower frequencies up to the mid-high frequencies but after it hits C7 or 8 (I'm not sure if it's that high) it will start to go down in pitch for about four notes then goes silent past that, my other one goes to this pitch easily. I don't know if it makes a difference but I accidentally put one 1N914 rather than an 1N4148 for one of the diodes on the slider board but I figured it didn't matter too much. Any help would be appreciated.
Also how do I wire up the HF out?
Thanks,
frijitz
Audio files: 54
PostPosted: Sun Jun 07, 2009 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I get a 404 on that and I couldn't figure out where to look for the samples. Which subforum?
Glad you got the tracking OK.
Ian
pristak
PostPosted: Sun Jun 07, 2009 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian:
Its in the same thread I started earlier. It is in the DIY subforum. They changed the layout and the DIY section is near the bottom now. I liked it better when it was near the top.
lexvortex: The HF out is wired directly from the pole of one of the 6 position switches.
pristak
PostPosted: Sun Jun 07, 2009 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, lets try this
Doubledeka w/cgs tube vca. Sequenced by Doepfer maq 16/3. Recorded straight into Cubase using a Presonus Firestudio. A little compression (UA Fairchild) and eq (UA Neve 1073) as put on in the mix.
pristak
PostPosted: Sun Jun 07, 2009 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I like this one better. Where did my fade out go in the last one? heh...
Doubledeka VCO, Into LPG Sequenced by Doepfer MAQ 16/3. About 1 minute in, exponential FM is provided by a Jerkster chaos. Recorded straigt into Cubase using a Presonus Firestudio, no fancy effects.
frijitz
Audio files: 54
PostPosted: Sun Jun 07, 2009 8:34 am    Post subject: Re: Problem with DDeka Reply with quote  Mark this post and the followings unread
Well, it does usually go down a bit as it approaches the very end of its range. But it shouldn't be happening so low. The diode substitution doesn't matter a bit.
Not sure what to look for. Solder bridges? Correct integrator cap?
First you have to have something to hook it up to. It's an aux signal for possible uses in other waveshapers, etc.
Ian
frijitz
Audio files: 54
PostPosted: Sun Jun 07, 2009 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I like them. Both fat and buzzy.
Ian
frijitz
Audio files: 54
PostPosted: Sun Jun 07, 2009 8:48 am    Post subject: Re: Problem with DDeka Reply with quote  Mark this post and the followings unread
Oh, you meant where on the circuit? At the highest position of the octave switch. Point "b" on the schematic.
Ian
lexvortex
PostPosted: Sun Jun 07, 2009 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ian,
Thanks for the responses Smile I figured out what was wrong... just 4am retardation Embarassed I had the octave switch up too high in comparison to my tuning source and got them all confused. Got it all sorted out today and both are working great!!
sduck
PostPosted: Mon Jul 06, 2009 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm just about done with the wiring on this, and wanted to ask about something that's been vexing me. On the pcb there is a hole marked v/o on the side next to R7. There's also a hole marked v/o over in J2, which is connected to R6. These both feed into the same place through identical resistors, so I'm wondering - why? Am I missing something?
frijitz
Audio files: 54
PostPosted: Mon Jul 06, 2009 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good spot. It's just an extra input, in case anyone needs it. So just ignore it if you don't need it.
Ian
