The Polyphonic Jack Choice?
Page 1 of 1 [11 Posts]
phdinfunk
PostPosted: Thu Sep 10, 2009 7:35 am    Post subject: The Polyphonic Jack Choice? Reply with quote  Mark this post and the followings unread
So initially I thought four voices for sure...
Use four prong XLR jacks.
Then I thought, three might be easier to manage, and could use normal XLR jacks...
Then it occurred to me?
What about Stereo 1/4" Jacks?
The only drawback I can see is the cable would not be shielded in reality (and I'd probably need to solder three wire cables to the plugs for best performance)... But I still wouldn't have any annoying banana jack scratch...
And I could have my poly modular with reasonable panel sizes...
But here's another question. Some of those jacks connect the ground wire to the screw on the front and to the panel (mechanically if not electrically)... so it might get some mondo nastiness that way...
Is it easy to locate 1/4" Stereo jack sockets that mechanically and electrically isolate the ground connection as well as the two main signal connections?
What does someone experienced think of my idea? 3 signals on every wire?
Any problems I'm not thinking of or should this work fine?
Thanks,
Jeannine
fluxmonkey
PostPosted: Thu Sep 10, 2009 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
no offense, but i feel like i came in on the tail end of a conversation with yourself... what are you talking about/trying to accomplish?
www.fluxmonkey.com
magman
PostPosted: Thu Sep 10, 2009 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
You can definitely get insulated Jacks, where the barrel connection is insulated from the front panel.
http://uk.farnell.com/switchcraft/114bx/phone-connector/dp/1298186
You may also be able to get 4 connection jacks in some cases.
I guess you are wanting to patch all channels of a polysynth in parallel (VCO output to VCF input for example), but you may have some issues using jack connections as they effectively short some inputs as the jack is inserted and removed.
You might be better looking at something like DIN Sockets, or Mini-DIN's (like the older style PC Mouse and Keyboard connections), especially as you can get these with up to 8 connections in a small shell. These are available in panel mounting formats like this:
http://cpc.farnell.com/pro-signal/psg01574/socket-4-pin-mini-din/dp/AV15032?Ntt=av15032
You can also get regular sized DIN sockets in a neat panel mounting format, at up to 8 way:
http://cpc.farnell.com/deltron/650-0800/8-pin-panel-socket-din/dp/CN00078?Ntt=cn00078
And another good thing for DIN connections, is that the ground connection is in the outer shell, so a ground connection is normally made before the signal connection.
Hope this helps
Regards
Magman
neandrewthal
PostPosted: Thu Sep 10, 2009 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
If you build a poly modular, you will be my idol.
slabman
PostPosted: Thu Sep 10, 2009 2:12 pm    Post subject: polyphonic jack choice? Reply with quote  Mark this post and the followings unread
RJ45s like in ethernet cables. everything - plus, sockets, cable, crimping tools - is dead cheap. you'll have 8 conductors. cable is shielded. you can even buy ready made patch bays on 19" racks.
next question please...
phdinfunk
PostPosted: Thu Sep 10, 2009 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think shorting connections as I'm inserting a cable should cause any problems since it would effectively be cross-patching the synthesizer but with connections that are "okay."
In other words, if I'm running an LFO to a VCF, do I care if for a half second voice 3's LFO is running to Voice 2's VCF, etc?
The nice thing about 1/4" jacks versus all the other options (which I considered mini-DIN but the RJ45's I never thought of), is that I can get heavy duty 1/4"-ers that will be okay for all the insertions and removals that modular patching tends to lead to....
I think I'd wear out DIN's and mini-DINs pretty fast.
--Jeannine
BOB-SNARE
PostPosted: Thu Sep 10, 2009 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some won't like this idea of sampling but...
You could always look into Time Division Multiplexing over a 1/4" jack.
That way an input attenuator will attenuate all polyphonic signals, and monophonic signals (let's say an LFO) could be used to modulate all polyphonic signals too (say VCO freq).
phdinfunk
PostPosted: Thu Sep 10, 2009 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also considered multiplexing but... I've built a lot of DIY from boards and parts... I'm comfortable with that, and I can wire complex systems, and I can build things like buffers just fine. Also, I've selected circuitry so my need for multi-ganged pots is only a few here and there... mostly I use offset voltages.
-BUT-
I am not at all confident in my ability to build a multiplexing system.
--J:.
Mooger5
PostPosted: Sat Sep 12, 2009 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I´ve seen mini-jacks with two rings lately. Supposedly for 2.1 audio systems. So it´s a stereo jack plus 1. I don´t know what they´re called, but you could ask at DIYAudio.com (electronic parts sub-forum). Good luck.
magman
PostPosted: Sat Sep 12, 2009 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I should have thought of these, as they are the jacks used on iPod's and some PDA's to give video along with the stereo audio (focusing too much on 1/4" jacks).
http://cpc.farnell.com/pro-signal/psg01500/plug-3-5mm-jack-4p-metal/dp/AV14958
http://cpc.farnell.com/_/mj-064h/3-5mm-jack-socket-4p/dp/AV15100
Regards
Magman
phdinfunk
PostPosted: Sat Sep 12, 2009 7:20 pm    Post subject: AWSOME! Reply with quote  Mark this post and the followings unread
Those are super.
I think that will be exactly what I want...
and a nice standard cable that I'll be able to find relatively easily also...
(As opposed to four pin XLRs or some such wierdness)
--Jeannine
