tonewill
Posted: Fri Oct 16, 2009 5:57 am Post subject:
Clone PCB from scanned image |
I had an idea to create a clone of an old PCB from a scan taken of it. I have scanned the track side of the board and played around in photoshop using colour selection and smoothing, but I'm sure that it would be possible to get much better results with much less manual touch-up work needed with the right know-how.
Anyone tried this or know of a tutorial somewhere? |
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Fri Oct 16, 2009 2:12 pm Post subject:
This is exactly how I am attempting to clone some Moog and Buchla modules. It is possibly the worst possible method to use Real caveman stuff. Someone will now chime in with streamlined, modern technology and a good chuckle at my expense. Best luck! (Be sure to put corner markers and possibly even a thin edge outline for board cutting.)
However, if the transfer methods allow for good double-sided results, it will have been worth every moment spent. _________________ We are selling emotions, there are no emotions in a grid. -mwagener
"IC 741. Sometimes you don't want fidelity." -Small Bear Electronics Catalog |
julian
Posted: Fri Oct 16, 2009 5:58 pm Post subject:
Ive created tool paths (for isolation milling) from scanned pcbs before.
I did not personally do the scanning but i believe that they were scanned (or possibly even photographed) and then printed onto paper, retouched using a physical pen, and then rescanned again.
I then used a trace function to create a tool path for milling the copper from the bare board to leave the traces, but for other reasons the board was never produced.
Obviously this is only possible on single side boards without removing all the components! _________________
For custom cnc engraved panels see - http://www.thebeast.co.uk/cnc/
parasat
Posted: Fri Oct 16, 2009 6:17 pm Post subject:
julian, when you say "trace function," is this part of your CAD/CAM software (and if so, what are you using)? Or is it a module in another program, or something you wrote yourself?
Enquiring minds want to know  |
Sebo
Posted: Fri Oct 16, 2009 6:59 pm Post subject:
Hi:
I did a PCB copy of my DR-110 that way, scanned it, then used Photoshop
treshold funtion to convert it to a monochrome kind of pic, then I worked
it by hand. I set a layer with the original scan set to 50% opacity to guide
me, and turn it on and off as I need it, and to verify is an exact copy.
I etched the PCB but never find the time to drill it, so is laying around unfinished
(as many other projects). _________________ Sebo
My Music:
https://www.facebook.com/cosaquitos/ |
scriptstyle
Posted: Fri Oct 16, 2009 9:55 pm Post subject:
| the "trace" function may be live trace in illustrator? honestly that would be the direction i would go in after adjusting my levels in photoshop, then i would select all the black, invert, delete, save as .psd import into illustrator trace and expand. then make adjustments. |
drapdap
Posted: Sat Oct 17, 2009 2:29 am Post subject:
Re: Clone PCB from scanned image |
hello guys...
i'm doing this method quite confortably since a while. (mind you i'm livin from doing graphics and animation.)
let me tell you that tracing these is a complete waste of time, i've been there, done that, tried setting up things in photoshop or gimp,
do equalising, do color selection, get it just about right, than try to trace it with flash, or inkspace, (i'm not too fond of illustrator at all) but there will be always smaller or bigger errors which you have to deal with by "hand". So why not work clean from the start, make a layer for you new pcb and draw over the traces. It doesn't need to be a scan, a good quality picture works too, i just free transform them until they don't distort the size.
Usually i give them better resolution (300-600 dpi) then go over the holes with creating a circle with a hole on a seperate layer, selecting it, and then move a copy of that over each component hole for a start. Same for the ic's, i just have these pre-saved, right size component drawings in a pdf-file...
my Wacom-tablet is my best friend for joining the dots, but with the photoshop selection tool you can get pretty far too, looking quite pro.
But anyway, i just wanted to tell you that from experience, this is a lot better method, almost the same, but better than try to clean a dirty scan, that's really caveman stuff, it eats time.
Attached is a redrawn Serge 1973 TWS (kit), from Ken Stone's site...
http://www.cgs.synth.net/synth/serge/tws.html
Strictly for edjucational purposes.
This was one of the first boards i did this way, looks still shakey, i do a lot better now, but that didn't stop me from building a working copy of this.
(I hope it's ok to post, dear Admins, this is old stuff, and up on Ken's site anyways...)
Now is there somebody with a good picture of the Serge Wavefolder?
róbert
 Download (listen) |
| Filename: |
Serge_TWS_0.6_PNP_A4.pdf |
902.9 KB |
| Downloaded: |
278 Time(s) |
Peake
Posted: Sat Oct 17, 2009 10:25 am Post subject:
| drapdap wrote: | | So why not work clean from the start, make a layer for you new pcb and draw over the traces. It doesn't need to be a scan, a good quality picture works too, i just free transform them until they don't distort the size. róbert |
That's what I'm doing...however, on the Moog, the boards are populated (single-sided). It is possible, following the schematic along with the traces, to make sure that every through hole is correct and each trace accurate. _________________ We are selling emotions, there are no emotions in a grid. -mwagener
drapdap
Posted: Sat Oct 17, 2009 10:52 am Post subject:
| Peake wrote: |
That's what I'm doing...however, on the Moog, the boards are populated (single-sided). It is possible, following the schematic along with the traces, to make sure that every through hole is correct and each trace accurate. |
Hi Peake!
yeah, checking the thing against the schemo is always necessary, i totally agree on that...
but redrawing helps me understand the circuit most of the times, so it becomes easier to modify the layout...
but parts today are so small that i sometimes end up shrinking a board, except for the sockets, so i keep them on a separate layer usually.
it starts to get messy by that time, so i always wonder by the end why didn't i start the whole thing in Kicad...
is it possible to know which Moog are you working on?
Somebody just posted the Minimoog-D pcb scans a while ago, but the
admin here (most rightfully) removed them quite quickly...
r. |
Peake
Posted: Sat Oct 17, 2009 11:58 am Post subject:
Hi, just the 901a/901b so far; when they're ready I'll post them (I have Moog Music's kind permission, and no one is manufacturing them so there is no conflict of interest).
Note that these use 1/2W resistors, so the boards are huge and the spacing very, very kind to those who hand-draw clone PCBs
The artwork is ready but I lack any knowledge of how to "select" the specified 2N 4058s (probably voltage matching). Cheers! _________________ We are selling emotions, there are no emotions in a grid. -mwagener
TekniK
Posted: Mon Oct 19, 2009 3:14 am Post subject:
| drapdap -> i did redraw the ringmod from kens site that way. |
tonewill
Posted: Mon Oct 19, 2009 7:28 am Post subject:
| Thanks everyone, I think you're right, re-drawing the tracks is the way to go. |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Wed Oct 21, 2009 11:36 am Post subject:
By the way, I've redrawn scans using Abacom's Sprint Layout, which might be the only pcb design program that let's you use transparent scans. It probably easier than something like photoshop since you can use the parts library to get the right footprints. And a lot cheaper than photoshop as well... _________________ http://www.casia.org/modular/ |
Peake
Posted: Wed Oct 21, 2009 3:06 pm Post subject:
| Etaoin wrote: | | By the way, I've redrawn scans using Abacom's Sprint Layout, which might be the only pcb design program that let's you use transparent scans. It probably easier than something like photoshop since you can use the parts library to get the right footprints. And a lot cheaper than photoshop as well... |
Thanks for the tip, that sounds like just the right thing! _________________ We are selling emotions, there are no emotions in a grid. -mwagener
drapdap
Posted: Thu Oct 22, 2009 6:11 am Post subject:
| Etaoin wrote: | | By the way, I've redrawn scans using Abacom's Sprint Layout, |
Thanks for the tip Etaoin!
Teknik: yes, Ken Stone's wonderful site is a sitting duck for people who'd rather spend time redrawing things than buying boards... i also did lots of things from there by looking at the pcb's and reading the schemo's while joining the dots, the psycho Lfo, the real ring, the small wavefolder, the bandpass filter, the burst generator, all simple but wonderful little circuits... I believe Ken knows this, otherwise he'd do double sided boards without pictures on the net, but how would you be hooked than? the first must always be free...
This pcb thing became like a card-game, collect all of them, who got the most wins. i really enjoyed getting into things a few years ago by diy-boards (free on the net, etched my own), it did fire my imagination, mind you, im not too fond of collectors, i just envy the knowledge. Also i see a value of an instrument is the time i've spent with it... of course there are better or worse violins, but one can play violin or not. And that's just time and dedication.
As for the Ring Modulator on Ken's site, it's hard to credit it to him, as it's in almost every older book about electronics or ham radio along with the balanced modulator, i've known that drawing from my dads books years before i got to make my own... Of course a layout is another thing...
erm, sorry for ego-trippin...
róbert |
