<on air> Twyndyllyngs tonight - special Sunday episode Chez Mosc
 Forum index » Instruments and Equipment » Soft synths
Looking for a totally insane VST...
Page 1 of 1 [20 Posts]
destroyifyer
PostPosted: Thu Sep 11, 2008 7:21 pm    Post subject:  Looking for a totally insane VST...
Subject description: ...that will make my computer explode.
I want a MONSTER vst that is insane, with tempo sync in mind. I have Moog Modular V along with basically every well known free VST on the internet, as well as a modular environment vst host ( I can hook them up all crazy like ect.)
So, please, help me out I'm looking for something that is beyond insane and is rediculous and will make my computer explode. I'm making this post, because I want to see if anyone knows what I'm looking for.
I want something INSANE that will make my computer turn into like a space robot that will enslave humanity. I mean, something that is seriously really cool. Prefferably something experimental and totally insane, and not an emulation. I'm sick of this "analog simulation" crap. This is the 21st cenutry and I want a space synth/vocoder that modulates its modulations with pico-HFO's and tempo syncs your brainwaves, while re-synthesizing its CPU fluctuating oscillator until it explodes. Any suggestions? Thank you.
BobTheDog
Audio files: 32
PostPosted: Thu Sep 11, 2008 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I don't know if it is insane enough but have you looked at Absynth, you can get a free demo at http://www.native-instruments.com/forums.html?id=demoversions&L=1&ftu=ff765a434f64b87
Andy
Floppy
PostPosted: Fri Sep 12, 2008 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds like lucifer to me : http://www.devine-machine.com/LuciferDemoPC.zip
sugar bytes effectrix can also be very extreme : http://de.youtube.com/watch?v=lsk1mJ_vwZw&feature=related
destroyifyer
PostPosted: Sun Sep 14, 2008 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you both. However, I'm not getting through to the "lucifer" vst. It seems to have fallen from devine-machine's product page. Thanks anyways though there are way too many VST's to make a sound choice.
BobTheDog
Audio files: 32
PostPosted: Sun Sep 14, 2008 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
How about reaktor 5 from Native Instruments.
Absolutely fantastic with some really weird stuff in the user library which contains hundreds of good instruments.
Demo also available on the NI site.
sunny pedaal
Audio files: 12
PostPosted: Fri Oct 17, 2008 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
BIDULE, cheap and combining of all vst's possible
XpanderXT
PostPosted: Mon Oct 20, 2008 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Reaktor - you can make your own exploding synths.
Tassman - very cool modular synth that weighs heavy on the Physical modeling side.
Tera - Virsyn's Tera is very modular and has all kinds of stuff. Use enough voices and your computer will explode or at least catch fire.
MAX/MSP - if you enjoy coding more than making music and want to do things that sonically only exist in the minds of mental patients.
SONiVOX
PostPosted: Mon Feb 23, 2009 10:38 am    Post subject: insane vst! Reply with quote  Mark this post and the followings unread
well if you are looking for something huge with tempo sync capabilities then I have two great suggestions for you!
first i'd say, try out MASSIVE by NI. it has a powerful engine with additive oscillators, filters, FX and assignable envelope, step and LFO mod controls.
http://www.native-instruments.com/forums.html?id=massive
another suggestion would be Playa virtual instrument. it is an MPC style interface 16 assignable pads and a re-trig tempo sync function.
http://sonivoxmi.com/ProductDetail.asp?Item=CDPlaya&mnu=LayVirtualInstruments
realtrance
PostPosted: Fri Jul 24, 2009 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
.. and for something a little more unusual and generative in nature, take a look at SYNPLANT. Truly an interesting little piece, the company I work at is actually using it for sound design.
boony
PostPosted: Wed Jun 02, 2010 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
MASSIVE by NI instruments for sure. extremelly powerfull.
i use ut for everything.
ansd if you do liek to do a bit of cheating there is a shitload of presets which you can tweak and what not.
Another one you may like to check out is Albino 3. found this great for makeing real hevay bass's
ausdjforums.com
KNOCKED UP NOISE
loydb
PostPosted: Thu Jun 03, 2010 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
+1 Massive.
Though Reaktor is a lot of fun if you're into low-level sound mangling.
destroyifyer
PostPosted: Mon Sep 06, 2010 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the suggestions, I'll have to check some of those out sometime. A friend of mine is habitually upgrading his computer (he's even implemented liquid cooling) and I've been meaning to give some of the more CPU heavy programs a try on his system. In my opinion, even existing complex soft synths demand much more computing power than is available to the average musician- it's no fun having such a finite number of virtual patch cables that can be hooked up. Although, I should probably try something running at 4+ GHZ before I take too many stabs at the present level of affordable technology.
DES
PostPosted: Mon Sep 06, 2010 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been digging into z3ta by Cakewalk (former RGC audio synth) more and really having a ball with it. might be a worth a look-see-listen...
www.davesneed.com
trancekid
PostPosted: Sat Feb 19, 2011 11:57 am    Post subject: Ok you want cool synth. Reply with quote  Mark this post and the followings unread
Why no one try Synapse audio Dune its the new hot soft synth out ther try demo and you see.
Geir
PostPosted: Sun Jan 27, 2013 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
U-he Filterscape is a nraly spaced out morphsynth
http://www.u-he.com/cms/filterscape
Reaktor:
Skanner http://m.youtube.com/watch?v=I1JcsgS66Sc (not free though)
Razor, heavy narly sounds to lushness extrodinare: http://m.youtube.com/watch?v=8a4XiqXwp2Y
I'new here btw, so hi everyone Smile
Geir
PostPosted: Sun Jan 27, 2013 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
And Chrystal of course.
http://m.youtube.com/#/watch?v=c_BTooOX7CE
Geir
PostPosted: Sun Jan 27, 2013 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one looks hidious, but can make some great sound.
http://www.ugoaudio.com/plug-ins/motion
memetix
PostPosted: Wed Jan 29, 2014 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
glad to see this thread still kicking!
vurtbox is weird enough to set fire to your frontal lobes, right down to the overly useless UI.
http://www.krakli.com/krakli-free-synths/
gladiator 2 sounds great and is so different as to blow minds:
http://www.tone2.com/html/gladiator_2_vsti_au_synthesize.html
glow worm
PostPosted: Mon Oct 27, 2014 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Try Sophia - available from http://www.audiobulb.com/create.html# If that doesn't drive you mad, then either nothing will, or you were mad already too much coffee
I've been getting some interesting results by controlling it with the Populus VST sequencer (http://www.xoxos.net/vst/vst.html#midi - where there are all sorts of other interesting goodies) either alone, or in combination with the Ball Sequencer from http://upland.no/download/.
I've also just downloaded the LFO MIDI parametriser from http://www.lauvadidzis.com/p/ilegacy.html - it's basically a VST LFO which can be output to any MIDI channel. I'm looking at using it to get even finer control over Sophia's parameters.
For rhythm, I often fall back on Cubix 1.2, running through the Paradigm Shifter effect - both available at http://www.psychicmodulation.com/plugins.html
The VST host from http://www.hermannseib.com/english/vsthost.htm is my playground / sandbox for all the above and more.
Hope that helps Very Happy
It may stop, but it never ends.
filboid
PostPosted: Sat Jan 31, 2015 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Spectrasonics - Omnisphere
By far one of the best VSTi ever and now coming out with version 2
http://vimeo.com/117503596
Jordan Rudess demo Omni 1
https://www.youtube.com/watch?v=zF8SYLjl07g
