Switched power supply to the modular synth?
Page 1 of 1 [5 Posts]
Pelle_punk
PostPosted: Wed Jan 19, 2011 9:33 am    Post subject: Switched power supply to the modular synth? Reply with quote  Mark this post and the followings unread
I wonder if it is okay to use a switched power supply to the modular synths or if there is lot of unwanted noise when you use one?
Cheers.
EdisonRex
Audio files: 172
PostPosted: Thu Jan 20, 2011 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is very easy to get a lot of unwanted noise. Linear supplies are easy to come by (or easy to build). You *can* do it, but for a proper analogue instrument, it's not a very good solution. If you are building an entirely digital synthesizer (not a modular), it's appropriate.
Garret: It's so retro.
Pelle_punk
PostPosted: Sat Jan 22, 2011 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank´s for the reply!
cbm
PostPosted: Sun Jan 23, 2011 1:10 am    Post subject: Reply with quote  Mark this post and the followings unread
At one point I would have said go linear, but switch mode supplies have gotten really good in recent years. They are smaller, cooler, more efficient, and when properly implemented, are plenty quiet for modular synth stuff.
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
Pelle_punk
PostPosted: Sun Jan 23, 2011 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your reply CMB.
I think I will build a MFOS "Wall wart" similar power supply, relatively inexpensive and simple construction, it was just that I have an LED Drive at home that´s giving + / - 12 volts
Cheers.
