Low Pass Gate?
Page 1 of 1 [7 Posts]
expermusic
PostPosted: Tue Jun 14, 2011 7:20 pm    Post subject: Low Pass Gate? Reply with quote  Mark this post and the followings unread
Does anyone know of a way, or perhaps an patch that enables low pass gate-like functions?
Thx!
It is obviously morethat just CVing a low pass filter and amp at the same time. How can I emulate the vactrol responses?
Macbook 2.4 Unibody/Nord G2 Engine/9u of Euro Modules/Elektron Machinedrum SPS-1UW/NI Maschine/Novation Remote Zero SL MKII/
Audio files: 297
PostPosted: Wed Jun 15, 2011 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd try a lag/smooth module for vactrol response, or maybe two to get a faster on response and a slower off response.
Audio files: 297
PostPosted: Wed Jun 15, 2011 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. just tried that - too complicated ;-)
Here is another idea :
seems to work sorta nice.
iPassenger
G2 patch files: 78
PostPosted: Thu Jun 16, 2011 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Jan,
Interesting patching. Smile
I notice the keyquant turns the audio rate signal to a control one, I didn't know that it did that. Smile
So if I get this right, the gate signal gets low passed, effectively smoothed and then sampled at the lower control rate (as you don't need it audio rate). Then acts as a envelope signal for the osc and the low pass filter? So presumably increasing the resonance on the first filter would increase the release? How could you control the sustain level or is this not usually possible with a lpg?
Also why is the constant used to pull the cutoff below minimum? Does that work?
Ross
iP (Ross)
Audio files: 297
PostPosted: Thu Jun 16, 2011 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I now wonder why I didnt just pick an envelope module .. Shocked
Yes, the quantizers can be used as blueifiers, and yes most modules will modulate below the minimum value set by knobs.
A vactrol is an LED that shines on an LDR, light = low resistance, no light is high resistance. LDRs tend to be slow, and tend to go to low resistance faster than going to high resistance. The pitch modulation from the gate (to the very low frequency filter) does this in the example above.
Well, anyway, at least it had some novelty to some Laughing
iPassenger
G2 patch files: 78
PostPosted: Fri Jun 17, 2011 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
hehe.. had a play around with this last night and I really couldn't tell the difference between using your lovely vactrol emulation (Jan) and a normal envelope. Could well be my ears though, they are crap. Laughing
iP (Ross)
Audio files: 297
PostPosted: Fri Jun 17, 2011 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Set the filter Q a bit higher, it'll then overshoot and undershoot.
