SubG (deactivated)
Posted: Sun Nov 13, 2011 9:00 am Post subject:
| Yes is Juergen Haible pcb's |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Tue Nov 15, 2011 1:09 pm Post subject:
Here's my work for the year, I know it's a bit ghetto style, but I'd rather spend the little money I have on functionality rather than looks.. I won't be doing any more work this year, as I'm in the process of moving (which also means I'll have a much needed dedicated workshop).
| Description: |
| Filesize: |
1.16 MB |
| Viewed: |
470 Time(s) |
| Description: |
| Filesize: |
2.02 MB |
| Viewed: |
423 Time(s) |
Sebo
Joined: Jan 07, 2009 Posts: 1220 Location: Scottish Borders
Posted: Thu Nov 17, 2011 11:02 am Post subject:
Impressive modular Rich , those spare spaces will fill up in no time
Dave |
fluxmonkey
LektroiD
Posted: Fri Nov 18, 2011 1:12 am Post subject:
| Skrog Productions wrote: | Impressive modular Rich , those spare spaces will fill up in no time
Dave |
This is my concern, my addiction will prevent it from stopping there..
Then I'm left with the dilemma; keep building on this 5U, or start a new project (maybe a 3U)? |
prgdeltablues
Audio files: 12
Posted: Fri Nov 18, 2011 3:07 am Post subject:
2011 modules - concentrated on the Klee sequencer and some utility modules. Also modded earlier builds to run on four way power headers (V+,AGnd,DGnd,V-) rather than just one ground.
CV mixer (cookbook)
Klee sequencer (e-m)[/img]
Hex AD/Ar (frijtz)
Quad VCA (nicolas)
VC clock (fonik)
| Description: |
| Filesize: |
206.03 KB |
| Viewed: |
366 Time(s) |
| Description: |
| Filesize: |
241.77 KB |
| Viewed: |
362 Time(s) |
| Description: |
| Filesize: |
240.46 KB |
| Viewed: |
356 Time(s) |
| Description: |
| Filesize: |
242.48 KB |
| Viewed: |
357 Time(s) |
| Description: |
| Filesize: |
1.69 MB |
| Viewed: |
327 Time(s) |
Posted: Fri Nov 18, 2011 11:32 am Post subject:
i'd like to see a pictire of the complete system - will be awesome, i bet. _________________
Tech Buddy at Random*Source |
ericcoleridge
Posted: Fri Nov 18, 2011 2:44 pm Post subject:
Nice work Flux.
Are those FPD panels? I'm just wondering if you had Serge Pot scales in HPGL/FPD? I'd like to get a hold of these scales
| fluxmonkey wrote: | | 3 ian fritz modules, 1 yusynth. that ChaQuO is awesomes. |
prgdeltablues
Audio files: 12
Posted: Sat Nov 19, 2011 4:28 am Post subject:
complete SDIY? no, you are right - almost impossible...
i like this ambivalent design: electronic, but with wooden GUI  _________________
prgdeltablues
Audio files: 12
nerdware
Posted: Sat Nov 19, 2011 5:47 am Post subject:
Are you sure that synth isn't edible? _________________ http://soundcloud.com/nerdware/
"render unto digital what is due to digital, render unto analogue what is due to analogue" |
jean-louise
Posted: Sat Nov 19, 2011 7:12 am Post subject:
it looks great! |
Joined: Jan 31, 2003 Posts: 18260 Location: Durham, NC
Audio files: 228
Posted: Sat Nov 19, 2011 12:24 pm Post subject:
| jean-louise wrote: |
it looks great! |
Delicious...  _________________ --Howard
my music and other stuff |
SubG (deactivated)
Joined: Mar 28, 2006 Posts: 1452 Location: Kansas City, Mo USA
Posted: Mon Nov 21, 2011 10:48 pm Post subject:
Sometimes I wish there was a "like" button for posts here! This thread is always an inspiration and I enjoy all the approaches to instrument building here. _________________ -- Kevin
http://kevinkissinger.com |
Photon
Posted: Tue Nov 22, 2011 8:08 am Post subject:
This is Grant Richters' Neural Pulser module. There’s a master clock with whole, 1/2, 1/4 and 1/8th divisions. The two banks of mini-slide switches are 2 binary rate multiplier based pattern generators. The outputs of all these divisions and multiples are patched to the 4 ‘Neurons’ (top half of panel) using stackable mini-connectors. Each Neuron has 2 Excitatory inputs and 1 Inhibitory input. A 3-way switch lets you select between the logic functions: not / or / and. So you get 4 different simultaneous patterns based on the same clock with related variations at the flick of a switch.
| Description: |
| Filesize: |
346.95 KB |
| Viewed: |
203 Time(s) |
| Description: |
| Filesize: |
236.26 KB |
| Viewed: |
216 Time(s) |
Posted: Wed Nov 23, 2011 7:36 am Post subject:
A new Weird Sound Generator Subject description: a gift for my granddaughter |
When my granddaughter visited last year she was fascinated with all the stuff in my studio and I asked her if she'd like me to build something for her. Well, she said, "Yes!". I asked her what colors she wanted and she chose a yellow panel with purple lettering.
Danno G will no doubt recognize the case -- it is from a mixer that he gave me during one of the swap and shops. Well, the mixer was pretty well used however the case made an excellent housing for the new WSG project.
The mixer was drilled for slide pots and the back panel had a lot of holes in it (it had been modded quite a bit). The holes in the back allow the speaker's sound to escape from the case and I just glued a grill cloth across the back. For the control panel, I simply made an overlay panel (in the opened up pic, you may notice some of the original drillings).
I added an internal amp/speaker to it however the unit has a audio ouput jack that, as expected, cuts off the speaker when a patch cord is plugged in.
I've had a lot of fun playing with the WSG. For such a simple circuit (six schmit trigger oscillators and a op-amp based filter) it makes so many sounds that I've already spent three hours just messing with it.
Well, my grandkids and son will probably love it -- not so sure about my daughter-in-law!
| Description: |
| The Weird Sound Generator |
| Filesize: |
1.49 MB |
| Viewed: |
236 Time(s) |
| Description: |
| The Weird Sound Generator under the covers. I mounted a little RS Amp and speaker. The battery clip is mounted on a 9v battery access panel for easy battery replacement. |
| Filesize: |
1.47 MB |
| Viewed: |
225 Time(s) |
Posted: Wed Nov 23, 2011 7:37 am Post subject:
Unique panel Photon ... I am "liking" it
Kevin ... yes a LIKE button would be cool. A "like counter" would be handy.
Bill |
Posted: Wed Nov 23, 2011 7:56 am Post subject:
and/or something like "MyLikes" in the signature? would this be codable? _________________
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Wed Nov 23, 2011 9:19 am Post subject:
Re: A new Weird Sound Generator Subject description: a gift for my granddaughter |
| kkissinger wrote: | | ...I added an internal amp/speaker to it... |
A Radio Shack intercom or room monitor? Oresome! _________________ Looking for a certain ratio since 1978 |
Posted: Wed Nov 23, 2011 10:40 am Post subject:
| emdot_ambient wrote: | | kkissinger wrote: | | ...I added an internal amp/speaker to it... |
A Radio Shack intercom or room monitor? Oresome! |
Yep! I had purchased one of these for use a pitch-preview amplifier for my theremins. In the meantime, I installed internal pitch preview amps so I just had this laying around. _________________ -- Kevin
