today> Twyndyllyngs cancelled tonight Chez Mosc
PCBs for Thomas Henry's X-4046 VCO
Page 10 of 12 [296 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12 Next
PostPosted: Mon Jul 09, 2012 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Z5U is the worst carbon capacitor you can get, i guess, however, they are cheap and i use them for decoupling. and that's what are the caps you referred to are for.
so yes, they are fine for this pupose.
PostPosted: Mon Jul 09, 2012 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW all who indicated interest in additional boards should check their PM#s and/or email...
elanhickler
G2 patch files: 6
PostPosted: Mon Jul 09, 2012 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Fonik! Another question!
Is it possible to remove the Coarse tune pot from the circuit? I just want to use the FM inputs to control the frequency. Basically, I would want to replace the coarse tune pot with a fixed resistor... maybe 50K so it sits half way through its range? How would I wire it?
PostPosted: Wed Jul 11, 2012 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
no need to do this. just leave off the potentiometer R43 and the according input resistor R29.
you don't need the fine coarse control then either? (R44, R56)
anyways, maybe you rather want to replace the panel mount coarse pot R43 by a trimmer? you could just replace the header by a PCB mount multiturn trimmer... Cool
elanhickler
G2 patch files: 6
PostPosted: Thu Jul 12, 2012 12:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought Todd Fletcher was offering a parts kit, but I've e-mailed and PMed him multiple times, no response... didn't even open the PM.
elanhickler
G2 patch files: 6
PostPosted: Sun Jul 15, 2012 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my panel. How do you like them's apple's? 8hp. No coarse tune. I will mostly be controlling this via Silent Way or use a DC offset module.
PostPosted: Tue Jul 17, 2012 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias.
Thanks for the quick delivery , all good & safe , im looking forward to building these Smile .
Cheers.
 Filesize:  150.43 KB
 Viewed:  831 Time(s)
PostPosted: Tue Jul 17, 2012 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Argitoth ......
Nice layout , classic knobs to the top and jacks at the bottom .
elanhickler
G2 patch files: 6
PostPosted: Tue Jul 17, 2012 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Skrog Productions wrote:
Argitoth ......
Thanks! I only do that if I have to and if I want to fit everything in the smallest space possible. If I really like a module, then I tend to make it small because I want many copies. Wink
inlifeindeath
PostPosted: Fri Aug 03, 2012 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm, so despite my requests in the past for more boards, i never got a notification that they were available again Sad ...
do you have any more boards left Fonik?
PostPosted: Fri Aug 03, 2012 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
currently not. someone over at muffs planned to do a eurorack panel (metalphoto top notch), alas, it did not happen yet. wanted to reßorder as soon as they are available...
inlifeindeath
PostPosted: Sun Aug 05, 2012 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's pretty disappointing considering i've already been waiting months for you to announce the newest run. oh well, gonna have to make my own.
PostPosted: Mon Aug 06, 2012 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
hey, all my fault! i am very sorry, it seems i did not track your request properly!
i want to sort this out right now! just tell me how many you need (up to 4 complete sets), and i will mail them this week!
PostPosted: Mon Aug 06, 2012 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
inlifeindeath
PostPosted: Mon Aug 06, 2012 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Once again verifying that Matthias is a solid dude and a true gentleman. All is well, thanks again!
elanhickler
G2 patch files: 6
PostPosted: Tue Aug 07, 2012 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Mr. Fonik, could you tell me the hole size and the #x # square that the PCB mounting holes sit on?
PostPosted: Wed Aug 08, 2012 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
PCB measurements:
the holesize is 3.2mm (0.126)
PostPosted: Wed Aug 08, 2012 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
notice that the PCBs could be mounted back on back. the power connector on the waveshaper is mirrored...
elanhickler
G2 patch files: 6
PostPosted: Wed Aug 08, 2012 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're crazy! no thanks! Twisted Evil
... Twisted Evil
PostPosted: Wed Aug 08, 2012 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
the idea was to mount them on bot sides of a bracket, so that you still can reach all thise trimmers.
i mounted them all in paralel to to the frontpanel, though Very Happy
PostPosted: Wed Aug 08, 2012 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm planning to use a long/flexible enough cable that I can lay them side-by-side/flat while I'm testing and tweaking and then fold it over and mount parallel but back to back as you say, Fonik. Needs a 2U wide dotcom panel to fit the jacks and knobs anyway, and it fits in parallel very nicely. (in my plans anyway Smile)
elanhickler
G2 patch files: 6
PostPosted: Wed Aug 15, 2012 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is C10 also used for decoupling?
PostPosted: Wed Aug 15, 2012 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes it is. it is going across the CD4046 from Vdd to Vss.
elanhickler
G2 patch files: 6
PostPosted: Wed Aug 15, 2012 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
marvkaye wrote:
http://w1.lancair.net/photos/2xNPNas394-2.jpg
Hmm... I don't know what to do with the matched transistors and 3k tempco I got from MFOS. Should I do it exactly like the picture above? Except I have thermal paste. Should I do it like the picture above except put thermal paste inbetween the transistors and sit the tempco on top and have some thermal paste on that as well?
Or maybe I can put the tempco between the transistors so the transistors touch the tempco and not each other and have thermal paste all inbetween?
PostPosted: Thu Aug 16, 2012 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i use termal glue.
transistors back to back like in the pic with a thin film of termal paste (glue), 2k PTc resistor on top (again with termal paste/glue).
ther termal conditions of the two transitors should be as equal as possible.
