creekree
Joined: Mar 30, 2006 Posts: 192 Location: Morgenland Neukölln
Posted: Tue Jan 14, 2014 4:03 pm Post subject:
Which Eagle libraries do I want? |
Hi all,
I ditched the PCB Layout Creator software and want to go with Eagle now. This is foreign territory to me, but I am willing to learn.
However, I am stuck when it comes to adding components - the stock libraries that come with Eagle are somewhat vast AND limited at the same time. Most of the components I do not know, the ones I want I can not find.
Which libraries would you guys recommend to get? I am a thru-hole only person, if thats any help...
Thanks! _________________
| sneakthief wrote: | | Your square wave isn't loud enough. |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Tue Jan 14, 2014 11:04 pm Post subject:
I wouldnt recommend any of the libraries but then i dont recommend Eagle either. , it's a ridiculous program I wasted a lot of time and effort coming to grips with it,
I still have it on my computer but only for the few designs i actually finished on it , but if you are set on using Eagle then you really need to take the time to learn to make your own library parts for it. Be aware dont trust any of the standard libraries you need to check parts against data sheets .
What i do recommend over every other program i have tried is FreePCB
simple to learn and use , fast , very few limitations and outputs gerbers, unless you want curvy traces , personally i can live without curvy traces. _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Wed Jan 15, 2014 6:25 am Post subject:
+1 on the mistrust of libraries, a lot of them are ok, but I recently did a run of boards with PC mount pots only to find out that both the mounting holes and silk outlines were too small.
I really like Eagle though, some things are a bit odd coming from CAD software like Pro/Engineer and Autocad (and Adobe Illustrator graphical design software), but overall I think it is pretty painless.
Defining your own parts is definitely very cumbersome, I have done it once or twice, but wow, very counterintuitive.
It's handy to have your own library though, just a single lib containing all the favorite parts in the stash, instead of Eagle loading tens of libs.
Tried freepcb, kicad, diptrace, just feels like a step down in ease of use.
Recently did a very small board in Fritzing, and liked that, for simple stuff it's pretty good (but will need to define a library there as well, because there isn't that much out there which has all relevant parts combined).
The licensing plan for eagle is pretty aggravating though, talk about limitations. Very limited unless you go for the most expensive version. |
yerpa58
Posted: Wed Jan 15, 2014 9:51 am Post subject:
I really like Eagle, and have used it professionally for decades. The best part is the way they use a single database for both the board and the schematic, it makes incremental design and revisions very easy. It is a far better design than some of the much more expensive programs out there. Also it is fast and unobtrusive on your computer.
You can google search for Eagle parts. Lately I found some good ones on the Ladyada site, also Sparkfun. Whatever program you use, do not automatically trust any part, always check with component data sheet. |
