3rd run for Thomas Henry's 555-VCO and Controller LFO
Page 1 of 4 [88 Posts]
Goto page: 1, 2, 3, 4 Next
New postPosted: Sat Jan 11, 2014 4:39 am    Post subject: 3rd run for Thomas Henry's 555-VCO and Controller LFO
Subject description: taking orders until 26 JAN 14
hi all,
due to several requests i promised to announce another run of Circuit PCBs, frontpanel components PCBs (eurorack) and eurorack Frontpanels for Thomas Henry's latest Projects (VCO and LFO).
so here we go. i will keep orders until 26 JAN 14.
As always i won't take any money until the goods are ready for delivery.
Please, tell me exactly what you wanted/needed, i.e.
"1 complete set of VCO PCBs/Panels"
or
"2 circuit VCO PCBs
+ 1 frontpanel PCB
+ 1 euro frontpanel"
you get the idea...
don't hesitate to contact me if you are interested in a completed module(handmade for you).
for the Eurorack Frontpanels i would need at least inquiries for a minimum of 30pcs, this is where the proce break kicks in. For less than 30 frontpanels i could not keep the price.
more details about the nice 555-VCO:
http://electro-music.com/forum/topic-56038.html
more info about the awesome Controller LFO:
http://electro-music.com/forum/topic-55470.html
pricing unchanged:
each PCB (circuit or frontpanel) = 7.50 EUR (~10.-USD)
printed front panel = 10.-EUR (~13.USD)
shipping international:
1 PCB = 2.-EUR (~3.-USD)
2+ PCBs = 4.-EUR (~6.-USD)
shipping deutschland:
1 PCB = 1.-EUR, 2+ PCBs = 2.-EUR
TH DIY Modules by fonitronik, on Flickr
__________
555-VCO BUILDING NOTES
1)
in the original schematic of the VCO frmo thomas henry we three times a resistor R26, whereas R25 is missing completely.
so here are the values corresponding to the PCB labeling that are not covered correctly by the schematic/parts list:
R25 - 300k
R26 - 39k
R55 - 5.6k
2)
when powering from 12V:
R13 = 2k
R27 = 22k
R33 = 137k
3)
when you have a hard time finding a precision trimmer wit 25k, just use 20k. should do the job as well.
4)
Try several LM13700 for best sine. the amplitude might differ quite a bit!
5)
C4 is the timing cap. use a nice C0G/NP0 or a polysterene for better stability.
6)
Parts for the Control PCB
for the pots any vertical mounted 3-pin 9mm pot should do, i used alpha and alps (for the values needed refer to thomas' schematic).
for the jacks i used the PJ301-BM. there is a new high quality version available with berillium copper from
THONK (Europe)
or
ERTHENVAR (USA)
to connect the control board to the cicuit board you will need single row headers and receptables.
if you build the VCO w/o the eurorack frontpanel components PCB you will have to manually wiring it up, which is a very reliable and easy to service solution IMHO. here is a diagram showing how the MTA-100 headers refere to the components:
for troubleshooting it might be helpful to have the silkscreen:
__________
Controller LFO BUILDING NOTES:
the chart below shows how to wire the potentiometers and the jacks, if you don't use the front panel components PCB:
ATTENTION: the PCB omits diode D2. i found the trigger to be fine without it.
however, if you experience occasional double triggers, solder it in parallel to R44.
ATTENTION: the P-JFET 2N5461 comes in different pinouts!
so check the datasheet of the specific brand you use!
(thanks to rosch for this find)
and here is the silkscreen of the circuit PCB:
StormB
New postPosted: Mon Jan 13, 2014 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
bin mit 2xLFO Platinen dabei
bod
New postPosted: Mon Jan 13, 2014 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
2x lfo printed front panels
2x vco printed front panels
I should have ordered these the first time along with the pcb's!!
Bod
scriptstyle
New postPosted: Tue Jan 14, 2014 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
^agreed
I am down for
2X VCO
1X LFO
adnauseam
New postPosted: Thu Jan 16, 2014 1:39 pm    Post subject: Me too Reply with quote  Mark this post and the followings unread
My first eurorack purchase!
I'd take 2 of each PCB
(4x pcb = 40 USD)
and 2 of each PRINTED front panel
(4x panel = 52 USD)
Plus I'm in Canada so 6 USD shipping (perhaps more? I'll take this as open to change)
98 USD if I calculated correctly.
adnauseam
New postPosted: Thu Jan 16, 2014 3:11 pm    Post subject: Newb question.. Reply with quote  Mark this post and the followings unread
So after looking at the original schematics at http://electro-music.com/forum/topic-54623.html I saw that it's talking about +/-15V where as I understand Eurorack specs to be +/-12v.
Haven't yet found alternate circuit diagram and being a novice I don't yet understand what to do to adapt it for 12v
Easy to accomodate?
AlasdairMoons
New postPosted: Sun Jan 19, 2014 8:03 am    Post subject: Re: Newb question.. Reply with quote  Mark this post and the followings unread
Easy to accomodate?
As far as I know the fonitronik modules they will run just fine with +-12V as well as with +-15V
No adaption needed Very Happy
my Music-Channel:
my Facebook:
alangave
New postPosted: Sun Jan 19, 2014 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm for 1 circuit VCO PCBs + 1 frontpanel PCB + 1 euro frontpanel
Will be my 3rd TH module, Fonik's design!
adnauseam
New postPosted: Mon Jan 20, 2014 6:56 pm    Post subject: Ooh I get it. Reply with quote  Mark this post and the followings unread
I misunderstood there as being a PCB and the option of a front panel - printed or unprinted.
I'll take:
1 VCO - complete set
1 LFO - complete set.
Ignore my previous post Smile
Rivelen
G2 patch files: 12
New postPosted: Tue Jan 21, 2014 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
1 x LFO PCB for me please !
Thanks.
uriahheep
New postPosted: Tue Jan 21, 2014 4:45 am    Post subject: 555 vco
Subject description: pcb
Hello
Can you put me down for
6 x 555 VCO circuit PCBS
Thank you
isacsen
New postPosted: Wed Jan 22, 2014 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in:
2 x circuit 555-VCO PCBs
2 x circuit Controller LFO PCBs
Trying to restart my modular building. This will be a nice project.
Thank you.
piedwagtail
New postPosted: Thu Jan 23, 2014 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
4 x circuit Controller LFO PCBs
please.
Robert
drapdap
New postPosted: Thu Jan 23, 2014 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello Fonik!
i'll take 8 pcb's of the 555-VCO's if that is possible, taht is 4 for me, 4 for
a friend, i build, he pays. Yes Matthias, he's more reliable than me. Very Happy
should i pm you?
robert
flyweight303
New postPosted: Fri Jan 24, 2014 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Mathias
Good to see youre doing another run.
For me please:
1 vco PCB
1 controll pcb
1 panel
4x pcb LFO
(removed 4 vco pcb's)
shiftr
New postPosted: Fri Jan 24, 2014 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
2x circuit VCO PCB's
please
shipping to the Netherlands...
Acilator
New postPosted: Fri Jan 24, 2014 1:32 pm    Post subject: 555VCO Reply with quote  Mark this post and the followings unread
For me,
2 X VCO complete (pcb's + panel)
2 X LFO Complete (pcb's + panel)
Also Shipping to the Netherlands
ioannis taf
New postPosted: Sat Jan 25, 2014 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Matthias,
I would like,please:
2 x circuit VCO pcbs,
1 x frontpanel VCO pcb,
2 x circuit LFO pcbs,
1 x frontpanel LFO pcb.
(and if available, older pcbs)
Shipping to Greece.
Thank you,
Ioannis
mono-poly
New postPosted: Sat Jan 25, 2014 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like 3 vco pcbs and panels
And i'd like 2 lfo pcbs and panels
jukingeo
New postPosted: Sat Jan 25, 2014 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
3 x VCO Circuit PCB
Shipping to 11702, USA.
Thanx,
Geo
Lover...I won't take a back seat, tonight. Got some dancin' to do.
avouts
New postPosted: Sun Jan 26, 2014 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
4 cirquit vco pcb's
and 2 adsr pcb's ( if available )
alfonso
New postPosted: Mon Jan 27, 2014 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
arghh! am i late? Embarassed Embarassed
i'd take 4 OSC PCBs and 4 OSC PANELS
piedwagtail
New postPosted: Mon Jan 27, 2014 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Alfonso, if you are from Ferrara anything is possible Smile
He's put the deadline back due to Chinese New Year - factory is closed- the post was updated at Muffs for 7thFeb latest orders.
Robert
alfonso
New postPosted: Tue Jan 28, 2014 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy yes i am Smile the beautiful magic city Very Happy
thanks for the info !
so i'm in for 4 vco pcb and 4 vco panels!
a.
New postPosted: Tue Jan 28, 2014 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
scriptstyle wrote:
^agreed
I am down for
2X VCO
1X LFO
just the circuit PCBs i guess?
