THT DIY vs SMD
Page 1 of 1 [6 Posts]
KammutierSpule
PostPosted: Mon Nov 30, 2015 5:49 am    Post subject: THT DIY vs SMD Reply with quote  Mark this post and the followings unread
Hello all,
is there any reason that we see more designs using THT (through the hole) components to be solder as a DIY kit vs using SMD (surface mounted devices) components already solder?
Does users prefer to solder it than make/buy the same functionality in SMD components (already soldered or as a DIY kit) ?
LFLab
PostPosted: Mon Nov 30, 2015 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
What you actually see is that more and more projects are using SMT.
I think more and more people realise it is actually not that hard to solder SMT.
I myself use both, I tend to use THT components for things like electrolytics and film caps, so signal fidelity. And also tend to use THT for resistors, because I have a lot of them. But bypass caps and actives are a lot smaller, really convenient to use SMT.
PostPosted: Mon Nov 30, 2015 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
More and more parts, the thru-hole version is being discontinued, but the SMD version is still being produced.
The way I see it, we're going to have to get used to SMD at some stage.
KammutierSpule
PostPosted: Mon Nov 30, 2015 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your comments.
But, I was wondering if there is any reason from the point of view of a user that have preference for equipment using THT (or that they build/solder their DIY) instead of buying a compact SMD version of the same thing. ?
PostPosted: Mon Nov 30, 2015 9:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Most people PREFER to work in thru-hole, due to it's large size and easy-to-work-with nature.
SMD has a steep learning curve, compared to thru-hole, but is still learnable and doable at home (as long as you avoid 0402 size.)`
PostPosted: Wed Dec 02, 2015 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
If I design a board I tend to use nothing but smd but at home I use tht.
I even buy little boards to convert from small packages to 0.1" pin distance in order to be able to breadboard these components.
